I'm about to wire in a CD player into a GQ. Are there wiring diagrams somewhere or can someone please give me a rundown of which wires are what.
Easiest way is to pop out the speakers and the attach the wires accordingly.
But both units should have diagrams on top to follow..
Sent from a device which doesn't always agree with my thumbs...
mate i always find the easiest solution is to find your power wire with a volt meter, then power up your radio. then just go along the remaining wires and wire in accordingly, this way there is no pulling panels off and that sort or kerfuffle. good luck!
You could also just get a plug and play system wiring harness aerpro make them local supercheap should have it
Is this what you are after?
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
Just make sure you don't use any of the factory wires for the earth, earth your CD player direct to the metal part of the dash frame.
exactly what i wanted Yendor
The easiest way to figure out what speaker is what is to get a small AA battery and put just go through the wires at the head unit and the speaker will make a popping sound, + multi meter for power ect. AND MAKE YOUR OWN GROUND! because sometimes using the factory ground can make your dashlights blow or brake lights fail
You may want to wire it hot to your aux battery if you want to use at camp etc
Leaving your start battery for just that, starting
Hi Spike, Just curious why using the factory ground blowes things? Is that head unit's fault or nissan's fault?
The earth that is usually picked on is only detected as an earth until your lights are turned on and it becomes a power feed for the factory stereo lighting hence the lights blow or the head unit doesn't work. Not sure where the factory Actually is ive never bothered to look, but it may be through the body of the stereo...
