GU driving lights
Got a set of the roolite xxx driving lights. Knocked up a little lighting control box with parts from Jaycar and a bit of angle bracket.
Parts used: -sealed ABS enclosure
- 30 Amp relay
- relay socket
- SPDT 3 position switch (plan to later add fog lights, the switch will then select between
driving/none/fog)
- 2 waterproof cable glands
- a few metres of 20amp pvc insulated cable. Each light draws about 10 amps but 20amp
cable keeps the resistance right down
- leftover speaker wire for the switch to relay.
- fuse socket
- 20A fuse
- cut piece of angle bracket
- solder lugs
- heatshrink
- terminal block
- 2 x 6mm screws. There are two tapped holes in the engine bay near the brake booster,
this seemed the perfect spot to mount the control box.
http://img515.imageshack.us/img515/6...0605132502.jpg
http://img443.imageshack.us/img443/3...0605165031.jpg
http://img404.imageshack.us/img404/3...0606085844.jpg
http://img253.imageshack.us/img253/4...0606112352.jpg
http://img850.imageshack.us/img850/3...0606143616.jpg
http://img14.imageshack.us/img14/745...0606204801.jpg
http://img17.imageshack.us/img17/231...0606204949.jpg
http://img845.imageshack.us/img845/9...0607130900.jpg
