Sorry guys about this stupid question,but does the indicator assembly in my gu 99 have 2 screws holding it in or do you simply take the top 1 off and prise the assembl:1087::1087:y out????
In mine there are 2 screws one small one and one really long one which acts more like a pin than a screw. remove these 2 then a small amount of pressure and she should pop out.
As above remove smaller screw on the plastic tab, using long nose plyers pull the other one up. there are 2 snap fit locating pins. Bit fiddly but come out ok. Just make sure they are fitted back in correctely so that long pin locates properly
