no vacuum to turbo actuator on zd30 engine
Hi, having issue with my wifes patrol. 4/92 y61 with zd30 turbo. I have no vacuum coming from the actuator solenoid. Have replaced MAF sensor. Correct vacuum coming from vacuum pump to solenoid. Vacuum hoses are fitted correctly. Battery volts on both sides of solenoid but I can't check square wave pattern to determine if pulsing but you can feel a very feint pulse through air hose. When direct vacuum is connected to Actuator it works so actuator is free and working. Car has lost power on take off and going up hills. I have no gauges connected but have ordered boost and Exhaust gauges for the vehicle. I will order dawes valve and needle valve on Monday to bypass system but need car for the weekend. Has anyone encountered solenoid failure on these or could it be an ecu issue? Turbo has no play and spins freely. Any help would be greatly appreciated
