HammerBuilder
Yeah like bill says multi panel, just as a quick note my 90ltr fridge on 12v is rated at 175watts so you may want to look into your fridges usages & calculate the total watts needed.
2x100 amp/hr batteries should be fine but if you have room stick at least 2x90watt panels as these will flex fine on the roof & are a manageable size. As for twin regulators not sure as if batteries are wired right they are like water tanks if 1 goes down the other will feed it till they are the same level. But I supose you could seperate 1 for fridge/ 1 for lighting but I think this would put more stress on the fridge battery if not kept topped up sufficiently by solar or other means, I mean 1 to 3 days may be fine but if its weeks you stay at places I'd keep both Batteries in parralel together this will be 200amp/hrs as compared to running 1 100amp/hr flat then having to switch over if it does run flat that is.
Once again check your specs on your fridge n see what calculates better for you. I use gas on my fridge most of the time as its very economical
& if I run out then switch over to battery if needed then if staying longer I just hook up to car n charge batt this way for 20mins if theres no sun.
cheers n hope it works out ok for you.
