front wheel bearings?
Hi all, just a quick question about front wheel bearings, jst called my mechanic who seems to think my gu series 2 my need them done. we have noticed a bit of a clunking noise when we turn right or mount the guttr to our driveway. the quetion is does this sound right. hope fully he will come an check them tomorrow
cheers
Pete
doesnt sound like bearings to be, get him to check all the bushes as well, certainly have the bearings repacked if they are a little loose
Clunking could be a vast amount of issues.
Wheel bearings could be one, but generally there would be other noises as well.
As Morton said, get him to check bushes and shocks, steering etc as this is more realistic
Pete & Jodie, I would check your radius arm bushes before wheel bearings my 96 gq ute made noises going up kerbs & such turned out bushes were stuffed, you can do it yourself if you are mechanically handy, buy nissan rubber bushes though last longer, and you'll need to get old pressed out and new pressed in about $20 a bush should be. I hope this helps you.
cheers Honest.
