Hi all,
After I picked up my new '03 GU - ZD 30 this week, I filled the sub tank, and pumped half of it to the main tank to see if the system works ok - seems to work just fine, but about 50km later after stopping for a bit and on re-start the check engine light came on - lucky I read the manual and knew the water sensor in the fuel filter also triggers that light, so I drained a bit of fluid of ( could not see what came out), but it made the problem go away, another 40km and a stop later and the same thing on restart. Drained a heap more fluid off, and since then no probs.
So I assume there might have been water in the sub-tank ( from condensation?), that was pumped to the main. The previous owner did say that he did not use the sub in the 2 years he had the wagon. I now want to drain some fluid off the sub tank, and the main tank for that matter before I pump the rest of the sub to main. Looked under, but could not find any drain plugs in any of the tanks - or are they hidden under the protection plates?
Any Ideas would be appreciated!
Kurt
