I cann't find fuse box in my car; 2.8TD. Could you help me?
Drivers side kick panel has a door that comes off.
Right near the bonnet cable.
yep like 97 says & the other mains are next to battery & relays are under metal plate beside main battery driver side of it
Hi. I can back up the previous replies. I have also come across a few in line fuses tucked up under the dash and inside the drivers side kick panel so...I guess it depends what isn't working as to where you search. Having said that, I think most issues would be with the most obvious and easy access ones. Cheers.
Hey does anyone happen to knpw what fuse cobers the map/spot lights? Tryong to put LED globes in there and nothing seems to wprk and i can't find witch fuse it is in the owners manual
I'm sure it has its own fuse , will check mine after my morning hangover cure .
Thinking it must be the fuse marked " clock , room " , if that's the case is your clock and interior lights all working ?
I can't find the engine fuse Nissan patrol 2014
Plz help me
