GU Bullbar LED blinker/park lamps
So the smashed blinkers in Big Reds bullbar probably needed changing rather than fixing so i bought some "L.E.D. autolamps 175AW" lamps to replace them.
http://www.nissanpatrol.com.au/forum...2013/03/78.jpg
also bought a "Tridon HD13" electronic flasher to stop the "flashes too fast" problem.
http://www.nissanpatrol.com.au/forum...2013/03/79.jpg
put it in Big Red [in case you don't know its a 99 GU Patrol Ute] before i fitted the lamps and the fuse blew.
tried another Tridon HD13 in MissRed [in case you don't know its a 00 GU Patrol Ute] and it blew the fuse there also.
The new 3 pin flasher cans plugged straight in to the existing plug but is not compatible with the wiring and no others i could find were compatible either.
will have to rewire it i guess.
original Tridon EP34
http://imageshack.us/a/img37/7840/guflasherzep34cir.jpg
electro mechanical type to suit LED's
Tridon HD13 suits 1 to 6 25w globes
http://imageshack.us/a/img69/9288/guflasherzhd13cir.jpg
Tridon SD13 suits 1 to 10 25w globes
http://www.nissanpatrol.com.au/forum...2013/03/80.jpg
