Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Hand Throttle
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Hand Throttle
    Hi guys and gals.
    I was speaking to an old Patrol owner and he asked me if I had a 'hand throttle' as they made hill climbs and descents much smoother.
    I had no idea what he was talking about.
    Any one know what he was on about?
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    yeah i got one but i think its meant to warm up the engine in cold weather
    201 Post(s)
    Quote Originally Posted by Mc4by View Post
    Hi guys and gals.
    I haven't got a pic but on a gq it is a little knob that you pull and twist to lock.
    I use it when going up very rocky climbs, because your foot is not bouncing around on the accelerator pedal it is a much smoother climb.
    Quote Originally Posted by garett View Post
    Nah mate... Back in the day all or almost all Landies, Tojos and Patrols had them and the purpose originally was for use with PTO equipment.
    Farmer Joe also found them handy for use as well sama sama the hand throttle on his Tractor.
    sunshinecoast
    3 Post(s)
    the more modern cars have a switch which raises the rpm to about 1300 , it is basically a fast idle switch to warm the motor up faster in cold weather . older cars had a leaver ( landrover , i think ) or a push/pull or twist knob to raise the rpm to basically whatever you want . i had an old hilux years ago that had a twist knob type , my gu has the fast idle switch . i would much preferr the twist knob as you could easily adjust the rpm faster or slower on the go .
    472 Post(s)
    Have never been able to use the twist throttle lock on any of my GU’s as they’ve always been missing the knob when SH purchased. Does make you wonder of their GU specific fixing methods. Had an old mate with a 1981 Hilux that foolishly wound his up for cruise control on the Newell Hwy and nearly killed himself when the backing nut came loose to off throttle on a corner. My old FJ’s back then had a better choke style cable that you could easily punch in on gnarly tracks when finished climbing.
    AB (10th July 2018)
  9. #7
    581 Post(s)
    Hand Throttle
    Just don't use it as a cruise control on freeways!
    Had a mate with an old hilux who used it on the freeway and coming up to a sharp corner he unscrewed it to slow down but the knob fell off and stayed on!
    He shat himself coming up to the bend so turned vehicle off but didn't leave it on accessories so the steering wheel locked up on the bend lol.
    Safe to say new undies were put on after that ordeal.
  10. The Following User Says Thank You to AB For This Useful Post:
    MB (11th July 2018)
  11. #8
    175 Post(s)
    Quote Originally Posted by nipagu7 View Post
    Also the modern cars with that warm up switch fitted disengage it as soon as you press the clutch and / or put it in gear. So you can't use it as a idle up a hill or anything. My 2009 crd patrol had that. But the gu 4.2 has the twist hand throttle.
  12. The Following User Says Thank You to Hodge For This Useful Post:
    MB (10th July 2018)
  13. #9
    sunshinecoast
    3 Post(s)
    yeah , my old hilux was an old 82 model and the knob came off but it was at standstill with the engine off . i was just winding it out to see how far it went to get an idea how much load it would give when using it , it was just a spur of the moment thing , otherwise i'd probably done it on the go . i can't remember what i did but i made sure it could'nt fall off again . i've only used the gu's idle switch for cold warm up , i don't think it would be good for much else .
  14. The Following User Says Thank You to nipagu7 For This Useful Post:
    MB (10th July 2018)
  15. #10
    581 Post(s)
    Ironic we had the same mate who did the same thing with the same name and same car....Strange
  16. The Following 4 Users Say Thank You to AB For This Useful Post:
    Avo (19th July 2018), MB (10th July 2018), mudski (10th July 2018), Rossco (10th July 2018)
