Page 843 of 1049 FirstFirst ... 343743793833841842843844845853893943 ... LastLast
Results 8,421 to 8,430 of 10488
  1. #8421
    461 Post(s)
    Started the big dash disassemble tonight. Just to remove the heater core...
  2. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Bacho86 (10th July 2018), Rossco (9th July 2018), Yeti's Beast (9th July 2018)
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Commiserations
  5. #8423
    461 Post(s)
    Quote Originally Posted by Yeti's Beast View Post
    Commiserations
    Thanks. I think. Its not too hard to do, theres just a crap load to take out. If the dash was untouched and original with no added gauges and all the other shite, I would have finished by now.
  7. #8424
    194 Post(s)
    Here are some shots taken of removing the king pin bearings on the front hubs, plus if you are doing the TB42 E brake upgrade, don't forget you need to transplant the original hub into the disk - I had a moment of freak out until I realised this also needeP6300335.JPGP6300336.JPGd to happen. Its a simple task, undo 6 bolts and ease the hub out of the original disk, then fit to the new, larger diameter disk. @MudRunnerTD, over to you my friend to integrate into your hub build or not!
    Also, don't mount your calipers upside down - make sure the bleed nipple is at the top of the caliper, otherwise you will spend the rest of your life trying to bleed the air out of the brakes. I know because I went thru 2 litres of brake fluid before the mistake was recognised.
  8. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    AB (9th July 2018), Bidja (12th July 2018), MudRunnerTD (9th July 2018)
  9. #8425
    194 Post(s)
  10. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Bidja (9th July 2018), MudRunnerTD (9th July 2018), Rossco (9th July 2018)
  11. #8426
    192 Post(s)
    Yikes ! Good luck. .
  12. #8427
    461 Post(s)
    God I hope I get it back together in time for Licola. I will be a dead man if I don't.
  13. #8428
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Mark, my GUIV only required the glove box unit to be removed, disconnect water, retaining bolts and core slid out of cradle to the left. Did you run a UV light over the residual fluid on floor to make sure it was not the A/C fluid weeping at the firewall flange joints and coming thru. This was the cause of my liquid on the floor mat (passenger side), ran UV over it and glowed. Guess you pressure tested cooling system to inspect core...Lot of work there mate.
  14. #8429
    Mark...
    We seriously need a selfie of your face when you read that...
    Right or wrong doesn't matter... just that instant in time as the brain processes the post should be priceless I reckon.
    Maybe even a good theme for the next months photo comp "The look on a persons face when..."
  15. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    mudski (9th July 2018), rusty_nail (10th July 2018)
  16. #8430
    461 Post(s)
    You sure that wasn't the A/C evap you are thinking of. As I have done mine before and that pretty much all I had to do. The heater box is located centre of the dash right above the transmission tunnel.
    Edit : See link for GUIV removal. Same as mine.
    http://www.nissanpatrol.com.au/forum...re-replacement
