Results 11 to 20 of 24
Thread: ZD30 just went bang....
    Advanced heaths_gu's Avatar
    Oct 2014
    Bathurst
    X2 with what yendor's thoughts are. I thought mine had gone bang not too long ago, but it was only the belt pulley had failed.
  2. The Following 2 Users Say Thank You to heaths_gu For This Useful Post:
    BigRAWesty (29th June 2016), Yendor (29th June 2016)
    Quote Originally Posted by shaun100 View Post
    Gday all, Help please. Driving along last night and all of a sudden a bang, engine stops and all dash lights come on. Pull over, engine cranks over as if it has no compression and a bit of a tinny sound / rattle. 2005 Gu 3.0 d AUTO. Any ideas what I can check or who I can get it towed to to have the problem diagnosed. Im in Perth north of the river. Thanks
    Whats the plan of attack ???
  5. #13
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    In my travels from shop to shop there is a growing trend of more CRD
    in for new motors, be it that timing cover coolant leak, or loose oil pump screws.
    Ive even seen them with 3 and 4 with holes, with the years ranging up into the 2010 plus.
    Mileage varied as well from as low as 30K
    I have been saying this for a little bit now.. CRD's are coming into that age zone.. all off a sudden the "Anti-grenade CRD's" are blowing up... Go Figure.
    My 03 keeps chugging along. lol
    2003 GU SIII Auto Grenade. All the goodies.
  6. The Following User Says Thank You to Softy For This Useful Post:
    BigRAWesty (2nd July 2016)
  7. #14
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by heaths_gu View Post
    I was thinking more along the lines of a stuffed flexplate.
    It doesn't sound like grenade symptoms to me.
  8. #15
    Jan 2016
    Be careful trying to crank it. If you've damaged a piston or valve or something, cranking it might cause more damage and end up costing more.
    Any oil in the intake or coming out of the exhaust at all?
    When it happened, do you know if it was blowing any smoke at all?
    When you say "all of a sudden a bang", do you literally mean it made a bang noise?
  9. #16
    When trying to start the engine does the drive belt on the front of the engine rotate?
    No mate......
  10. The Following User Says Thank You to shaun100 For This Useful Post:
    Yendor (30th June 2016)
  11. #17
    Hi All, sorry for late reply. A bit pissed off and thinking what to do!!
    When it happened it wasnt under a great deal of load, there was no explosion sound or anything (honestly cant remember the exact sounds it made) and the engine stopped, all dash lights came on and I rolled to side of the road, I got out pretty much straight away and didnt see any smoke etc,..
    I did notice in the few hours prior to this happening that when driving there was more of a "rattle" sound to the engine..enough that I stopped to listen to it, but it only happened under load.
    When I try to crank it now, its as if the starter is NOT engaging anything, and the front of the crank isnt spinning.
    Research indicates possibly sheared flex plate bolts, as its an auto. Come to think of it, ever since I had the car if I drive with overdrive on, theres a fine vibration through the car when it gets into the upper gears, enough to piss me off so I permanently leave OD off, torque converter out of balance possibly??
    At this stage, Im going to remove the starter on the weekend and look in the hole to see the situation of the flywheel.
    I will then try to find somewhere I can take it, for further inspection / repair.
    Anyone free this Saturday to do some fault finding in Perth :-)
    Thanks for the responses so far....
  12. #18
    Me too apparently happens often......
  13. #19
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hopefully this is your problem, as is will be the cheapest easy fix. As long as no damage was done to the crank.
  14. #20
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Where at mate. PM if you don't want to put up address. I have plenty on for Sat but might be able to come past during the day or on Sunday.
    Tony
