23rd May 2016, 02:28 PM
#1311
I hear you but dont hold me to ransom lol.
Id love to go and meet all the guys but its just
not possible Im afraid.
I do realise this may be the only time this will be possible too
Ill PM you later.....lol
23rd May 2016 02:28 PM
1st June 2016, 09:29 AM
#1312
MudRunnerTD
Well been doing a bit of bar work, my nephew has been down to give me a hand as it's basically impossible to do alone. Coming together slowly.
Pretty stoked with that!!
After our experience with a recovery hook Darren I am very surprised you are sticking with one and not using something like this..
The Following User Says Thank You to Lights For This Useful Post:
MudRunnerTD (1st June 2016)
5th June 2016, 07:38 PM
#1313
Moderator
Cheers Paul. My rear bar also has 2 recovery points built in to take a shackle do the hook will be used for towing and light snatching only. As we discussed with a 24v winch snatching will be rare.
Check out my Toy -->
Rogue Dung Beetle
5th June 2016, 07:49 PM
#1314
Moderator
The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (5th June 2016), BigRAWesty (5th June 2016), Clunk (5th June 2016), MB (5th June 2016), Plasnart (5th June 2016), Rossco (5th June 2016), threedogs (5th July 2016)
5th June 2016, 07:58 PM
#1315
The 747
You're getting good at this Darren
The Following User Says Thank You to Winnie For This Useful Post:
MudRunnerTD (5th June 2016)
#1316
MudRunnerTD
Tis looking good mate..
Also a hole saw makes notching a breeze..
Match the saw size to the pipe and drill away on the angle needed..
5th June 2016, 08:28 PM
#1317
Moderator
bigguwesty
Yeah but then I need to hold it at the right angle. These are hand cut with the 5" grinder and I am doing them pretty quick.
Rogue Dung Beetle
5th June 2016, 08:31 PM
#1318
MudRunnerTD
A bench vise works well..
Orrrrrr..
http://www.ebay.com.au/itm/262458679040
The Following User Says Thank You to BigRAWesty For This Useful Post:
5th June 2016, 08:57 PM
#1319
Moderator
bigguwesty
Yeah to be honest I actually planned to buy that notched and use a hole saw. I saw a YouTube vid on hand notching and figured it's not hard so I didn't bother.
If I was doing a complex cage or something then I'd have grabbed the notcher for sure. My mate who owns the bender has that notcher and I could have grabbed it to.
All good. Smashed them out.
Rogue Dung Beetle
4th July 2016, 10:21 PM
#1320
Moderator
Got a bit done on the weekend. So everything is tacked up right.... So I need to unbolt everything and remove all the bar work off the car to get a heap of welding and grinding done ready for paint. I unbolted the rear bar and stupidly tried to remove it alone and broken the left darling wing off!! Grrrrrr. Cleaned it up and got Naomi to hold it while I tacked it again. Needless to say Naomi helped me unbolt everything.
I also did some work to my winch. It's been in pieces but just need to put it together, might grab a Freespool blanking plate I reckon.
Rogue Dung Beetle
BigRAWesty (5th July 2016)
