25th May 2019, 07:11 AM
#21
I'm not a fan at all. High load, rotationg alloy steel on thin synthetic strands.
It will melt it.
And grit will make it worse.
The anodising will wear into it.
Blocks using bearings are a far better idea as there is no sliding parts. It's all rotating..
threedogs (26th May 2019)
25th May 2019 07:11 AM
25th May 2019, 07:26 AM
#22
MudRunnerTD
Hmmm i dont get pop up adds watching thar phil, only once at the start?
But no, the ring rotates just like a conventional snatch block. Instead of the bearing spinning the ring spins around the centre soft shackle.
I am back out at the mine, internet is about as fast as a dead slug at times, well below dial up. We have a Telstra tech out here for the last week trying to resolve, almost dead phones as well, so any pop up at this speed makes viewing next to impossible, maybe its one pop up, but for me it never ended and the video keeps stopping and refreshing. (this update will take over 10 mins to send) Anyway, principal understood, more relaxed now I know the ring actually rotates as well as it drops the frictional load between rope and donut, but over time, the dirt will abraid the rope and life will be reduced. I guess when I balance this against the number of times people will actually need to use the device, it will be fine. My approach is perhaps more conservative as I am using cranes and lifting devices, some lift plans take hours to resolve to be honest and on the job we are completing right now, the lifts have been analysed and challenged and reviewed at least a dozen times - I am sick of it to be honest, but when we do the work, it goes well. We work in highly controlled and regulated environs, as opposed to the loose recreational world, hence my responses may be framed within a different context. Anyway Daren, thanks for the explanation, good stuff.
25th May 2019, 07:39 AM
#23
Not cheap, available from Drifta check here
The Following User Says Thank You to TimE For This Useful Post:
MudRunnerTD (25th May 2019)
25th May 2019, 08:37 AM
#24
Moderator
bigguwesty
It will melt it.
Nah no way mate. Remember the sacrificial here is the Soft shackle. That will be the wear surface. When your soft shackle is dirty beyond service then your should replace it.
Same goes for your winch rope. When its at end of life replace it. You guys really are over thinking this i reckon.
Think about how slow your winch speed is througha snatch block. SLOW
Check out my Toy -->
Rogue Dung Beetle
25th May 2019, 08:39 AM
#25
Moderator
TimE
here
Yeah a snatch block of decent quality will coat you $100 too though. Not too bad
Rogue Dung Beetle
25th May 2019, 08:41 AM
#26
Moderator
bigguwesty
It will melt it.
Hard Anodizing too
Rogue Dung Beetle
BigRAWesty (25th May 2019)
25th May 2019, 08:44 AM
#27
MudRunnerTD
Speed is not needed if you you have load and friction.
And you and I both know that test in the video was soft.
Slight uphill unstuck car on hard ground..
Sent from my SM-G975F using Tapatalk
#28
Moderator
PeeBee
Cheers Phil, sounds like fun.
At the end of the day we are plating in a space using synthetic rope. The usage and environmentals dictate a shortened working life. If people respect the need to keep gear clean and abrasion free and inspect regularly (like they should anyway) them risk is mitigated.
If all the recovery components are in good condition then this Will Not be the weakest link
Rogue Dung Beetle
25th May 2019, 09:05 AM
#29
Problem solved. A teflon tube as bearing. I thought a teflon washer would be the go between the knot and ring but that would act as a cutter at the centre. If the anodising was damaged at all, it would quickly corrode as same as an anodised fairlead, wouldn't it?
25th May 2019, 09:23 AM
#30
This is great discussion.
I brought this up, as last weekend I was going through what to pack for my trip and unpacked my snatch block & shackles. I need to get rid of unused things and reduce weight.
Carried the snatch block around for a 1000 years and never used it, but understand its usefulness. I've replaced the shackles with soft ones and am tossing up about this ring thing.
I've not watched the vid yet, but I can understand how the ring would rotate around the shackle if for no other reason than the rope is wrapped around the ring, or the rope has more surface area contacting the ring than the shackle so the rope will have more 'power' behind it to rotate the ring than the shackle which is stationary. Happy to be told I'm wrong, I'm not an expert.
My driving would see me maybe wearing this out in a gazillion years, but saving weight in my vehicle immediately.
This would be a good item to organise as a group buy I reckon.
The Following User Says Thank You to 10G For This Useful Post:
