Page 44 of 105 FirstFirst ... 3442434445465494 ... LastLast
Results 431 to 440 of 1047
  1. #431
    472 Post(s)
    She looks a beaut Mick, Jay Mate you should See if a Tradie Mate can collect one for you too
    https://www.bunnings.com.au/a-message-to-our-customers
    jay see (9th August 2020)
    Quote Originally Posted by Mickhead View Post
    Saw this at Bunnings today. Is good. Have one. Attachment 81668
    Looks great but it doesn't do Mig Bugger it. If it did I might grab it myself.
  5. #433
    461 Post(s)
    Why wouldn't you use it?
    It’s a limited numbered collectors item. Once my room down stairs is done I’ll get another dart board to use.
  6. #434
    49 Post(s)
    Or you could give it to me and I'll use it. Limited number collectors. 🥱
  7. #435
    .......... TPC's Avatar
    63 Post(s)
    Would be worth more with some holes in it.
  8. The Following User Says Thank You to TPC For This Useful Post:
    MudRunnerTD (10th August 2020)
  9. #436
    461 Post(s)
    $550 and its yours.
    Definitely not.
  10. #437
    461 Post(s)
    Wanting to buy a welder..
    Something just for the odd job at home.
    What have people got and what do you recommend.
    John I bought a Cigweld gas/gas less welder. Cost about $100 a year to rent a gas bottle. It’s cheaper these days to buy outright and just fill it when needed.
    Mines not too notch but it has work well for anything I’ve used it for.
  11. #438
    49 Post(s)
    The MST185 is excellent too Attachment 81669Attachment 81669
    This looks good. It's a MIG Gas/Gasless and MMA/Stick electrode as well as DC TIG welder.
    Bunnings have it for $500
    I see yours is a130 amp. Do you trip your power when using it. Talking to a few welders at work they all said go at least 170 amp.
  12. #439
    461 Post(s)
    Thats welders talking... I welded 3mm plate on the bull bar with this mig not even on the highest setting and it worked a treat. I'd have to look at the spec on the inside of the access panel on the welder but I think it does up to 5mm. And my house was built in the early 70's, original house wiring, and I have burnt the house down. The breakers didn't go off so its not overloading the system.
    The welder was on special somewhere when I got it. It was cheap. But bloody handy. And being Cigweld, they are a good brand so it was a no brainer.
    One day I will upgrade with a Tig, not sure if I would use this or not. The welder doesn't get used much at all. I've had the same gas bottle for four years. Lol.
  13. #440
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I've got a tig and am always on the look out for a cheap/good mig. The tig is very handy but a bit tricky to get used too and significantly slower than a mig. I would save your pennies and stick with the mig unless you had a specific job for it or had the cash burning a hole in your pocket.
    I'm not a welder though.. So take that with a grain of salt.
  14. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MB (13th August 2020)
