5th April 2017, 11:05 PM
Pretty sure Ferntree Gully bolts (on Burwood hwy) and Bayswater bolts are owned by the same mob, so hopefully they'd be able to cross check to see if the other store had anything for you
The Following User Says Thank You to Bacho86 For This Useful Post:
5th April 2017 11:05 PM
6th April 2017, 02:32 AM
dom14
1cm-1.5cm should be enough for me.
Ebay ones are stainless steel, which is ideal for my application(exhaust O2 bung), but can't wait.
If you've gota one to spare, let me know.
No go, 3/4unf, and no beer in the fridge, daughters boyfriend already drunk it all, again!
6th April 2017, 09:16 AM
I'll have a look through my bolts for you ,
6th April 2017, 09:24 AM
Pretty sure 18mm 1.5 is same same as older Hilux sump plug! Only short but correct thread. Try local wreckers or local spare parts shop. Should be readily available!
The Following User Says Thank You to Touses For This Useful Post:
6th April 2017, 09:59 AM
Touses
Was thinking its about the size of a sump/gearbox or diff plug.
6th April 2017, 05:17 PM
what thread do larger spark plugs have????,, I know the smaller ones are 14mm x 1.5 pitch
6th April 2017, 06:30 PM
#17
you can buy o2 sensor bungs..any decent exhaust joint should have one or just grad a stuffed old sensor from the wreckers to plug the hole
gone to the dark side 2017 vdj 79 dc
The Following User Says Thank You to billyj For This Useful Post:
6th April 2017, 11:14 PM
#18
6th April 2017, 11:15 PM
#19
threedogs
Yeah, but bit hard to find them these days, I reckon. Most vehicles use 14mm.
