Page 403 of 564 FirstFirst ... 303353393401402403404405413453503 ... LastLast
Results 4,021 to 4,030 of 5640
  1. #4021
    North brissy
    $527.82 to be exact. Should get them today or Monday. Still a fecking lotta coin though for hubs. It will be interesting to see the build quality of the internal gear between the Chinese unit and OEM.
    I would imagine it to be quite a lot better. I have run 35s for years with standard hubs and never had an issue. The old GQ use to cop a hiding as it was basically setup as a play rig and its hubs still worked as per normal. Never saw any wear to cause alarm and I had it apart quite a few times doing wheel bearings and seals cos I would torture them.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (11th August 2017)
    201 Post(s)
    One of my OEM hubs has been jamming up recently. Once I have locked it I have to use pliers to unlock it. I'm yet to pull it apart and check it out.
  5. #4023
    22 Post(s)
    I'm still running the original hubs. I've destroyed CV's and snapped a short side axle, but never a genuine hub. I have always had one of thse hub strengthening rings too.
    96 GQ coil/Cab
    08 G6eT
  6. #4024
    22 Post(s)
    Pretty easy to do. It may just need a birthday.
    96 GQ coil/Cab
    08 G6eT
  7. #4025
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I bought a Joolca ensuite shower tent. I've been waiting and hoping they'd change it from the bright blue colour, but no luck, so blue it is!
    This thing goes up pretty easy and will offer us some privacy when camped near others. It seems like pretty good quality, but time and use will tell. I also bought the hose and shower rose kit that can stay in the tent when it is folded up, this will make it pretty quick and easy to setup for overnighters only. I'll get my glind heat exchanger and thermostatic mixing valve set up in the patrol this weekend, ready for a 6 week trip departing next weekend
  8. The Following User Says Thank You to stevemc181 For This Useful Post:
    MB (11th August 2017)
  9. #4026
    201 Post(s)
    Quote Originally Posted by stevemc181 View Post
    I've got the same tent, it's the one I had set up at AB's donk party on MB's property. It's a bloody awesome shower tent!
    I've got the shower rose too but haven't used that yet.
  10. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (11th August 2017), stevemc181 (11th August 2017)
  11. #4027
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Yesterday I ordered some kevlar sleeves for my firestone coil rite bags. Quoted price from some re-sellers $170+. Direct from airbag man $75. Also got the correct spacers for my lift. Only ordered after lunch and arrived today.... QLD address on the invoice sent to Vic not bad delivery time. Highly recommend the service there, online chat was good and then on the phone no fuss and knew there products.
  12. The Following User Says Thank You to sooty_10 For This Useful Post:
    MB (12th August 2017)
  13. #4028
    Bendigo
    7 Post(s)
    I also finally ordered this week some gas bonnet struts off eBay. I should have done that 5 years ago as it would have saved a few head knocks, a lot of pain in the arse stuffing around and an iPad screen.
  14. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    MB (12th August 2017), Sir Roofy (12th August 2017)
  15. #4029
    Patrol God Stropp's Avatar
    31 Post(s)
    Not today but a week or so ago I ordered 2 glass emu wing lift up windows on special with no freight cost saved $236 👌
  16. The Following User Says Thank You to Stropp For This Useful Post:
    threedogs (15th August 2017)
  17. #4030
    i know what i have to buy .............does that count
