Results 1 to 10 of 13
Thread: 1998 TB45 Dual Fuel Hard to Start in Mornings (sometimes)
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    My Patrol some mornings is extremely hard to Start and when it does only runs on about 4 cylinders for a couple of minutes.
    Normally I start with no Pedal but when it plays up I have to depress the Accelerator fully . It then starts after quite a few attempts.
    It then runs smoothly and will start first time for the rest of the Day.
    The Car always starts on Petrol and switches to Gas after a couple of minutes.
    It is like it is over fuelling if it fails to start first thing.
    Hope you can understand my ramblings but before I take it to a Mechanic does anybody have any ideas ??
    Mar 2015
    plugs leads ..... not sure if these have a dissy as such rotor cap and button ... how are your fuel filters recently got fuel from somewhere you have never used b4 ...... i know gas cars can be hard on spark plugs
    I never go into the outback with out a decent supply of water,
    and the general rule for how much you'll need is three litres
    per day , per person, per man per degree over 25 degrees
    celcius, per kilometer if walking on foot, in the winter months
    dividing it by two, plus... another litre... at the end .... Russell Coight
  4. The Following User Says Thank You to Makka For This Useful Post:
    Bob (25th June 2016)
    49 Post(s)
    Could be a number of things. As mentioned above I would be starting with plugs if they haven't been changed recently, then leads.
    Sent from my XT1068 using Tapatalk
  6. The Following User Says Thank You to jay see For This Useful Post:
    Bob (26th June 2016)
  7. #4
    Hardcore
    central coast nsw
    A comprehensive service on plugs, leads, vac lines , etc needs doing firstly.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  8. The Following User Says Thank You to Robo For This Useful Post:
  9. #5
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    then the coil pack, and then the Injectors themselves
  10. The Following User Says Thank You to Bigcol For This Useful Post:
  11. #6
    Oct 2010
    Pakenham
    47 Post(s)
    Thanks for the replies guys and have taken all on board.
    The bloody thing started first go this morning . It was 0 Degrees.
    However I will do as you all have suggested .
  12. #7
    sounds like you you have plenty of spark, but lacks a bit of fuel for start up.
    Does your model have that inline cage filter, ??
    Maybe give it a few pumps throttle wise on start up and see if that helps,
    you must be getting up there mile wise now??
    Replace all the vacuum hoses, cheap enough to do, and renew some of the fuel ines as well
    Could be they have perished and cracked over time.
  13. The Following User Says Thank You to threedogs For This Useful Post:
    Bob (6th July 2016)
  14. #8
    Jan 2015
    Hey mate, I'd be getting your injectors done if I was you, I had the same sort of thing going on with my tb45 GU, turned out 3 of the injectors were 70% blocked, and the others were leaking profusely when the engine was not running, causing it to be very hard to start.
    Good Luck!
    Sent from my SM-G928I using Tapatalk
  15. The Following User Says Thank You to Nickgu For This Useful Post:
    Bob (3rd July 2016)
  16. #9
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by Nickgu View Post
    Good Luck!
    Thanks @Nickgu Booked in to get that and other things to be serviced. Funny thing is the Truck is starting first thing and running well at the moment.
    Still getting all things serviced
  17. #10
    Hardcore
    central coast nsw
    Maybe as the temps a bit cooler, the computer is choking it a bit more and your now getting that bit more fuel that's needed to start better.
    The fellers could be onto something , just dirty injectors?.
  18. The Following User Says Thank You to Robo For This Useful Post:
    Bob (6th July 2016)
