Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: Coil Tower Braces
    Beginner Gertie's Avatar
    Jun 2015
    Hamilton Vic
    [QUOTE=Dr Gary;613404]
    Quote Originally Posted by Gertie View Post
    So I realized I had a huge crack in my driver's side rear coil tower, a common problem it seems with GU's.
    After reading quite a few threads I decided to repair then fit a pair of Boss Coil Tower Braces.
    Easy job if you have access to a hoist, and certainly worthwhile as a preventative measure if you haven't already.
    I went with the Boss ones as they helped pull the tower back into line to make it easy to mig up.
    They are east to fit, just bolt straight in, a couple of the driver's side nuts are a bit of a pain to get on the top, had to bend up a bit of metal to hold it in place, but apart from that a piece of cake.
    Also chucked in a 2" lift and set of 35's while I was at it, looks sweet now! Took her for a drive up the Grampians for the long weekend and she handled beautifully
    Looking at your pics, it seems you need to drop the axle and springs, fit the "Boss" then reassemble. It also looks like the rubber isolators fit around the coil tower. Is this correct??? Thanks
    BTW my towers are ok now--just looking for insurance.
    Hi Dr Gary,
    Did my father's with jacks and axle stands, opted for the hoist with mine, saved a heap of time.
    If you're doing it with a jack: Jack from chassis, unplug diff breather, take central brake bracket, then remove shock and the axle drops away, (if you unbolt shock first remember to take diff breather and brake bracket off first), take spring out, remove the bump stop, and if you don't have any damage just bolt the new one in!
    Only tricky bit was 2 of the nuts on drivers side are a pain in the a**e due to their position above the tower with fuel flow and return lines, I just bent a small piece of scrap metal to help hold them until I got the bolt started.
    If yo do have damage I would still recommend fitting the brace first as it helps pull everything together.
    Start with the top 4 bolts first and bolt in the bump stop and chassis bolts last.
    Much easier to do it on a hoist though
  2. The Following User Says Thank You to Gertie For This Useful Post:
    Dr Gary (26th June 2015)
    Gold Coast
    Hey Gertie
    Great information. I will use a hoist and the rest seems straight forward so long as I unhook brake bracket and diff breather. Pretty much as I suspected but best be sure.
    Gary
    Hi Dr Gary,
  5. #13
    Jul 2015
    Scarborough, WA
    Hi all, does anyone with the "Boss" tower braces fitted know if there are any issues with airbag compatibility?
    I don't think my towers braces are cracked, but seriously considering doing this mod before my next big trip, as I tow a 2Te camper and expect to be doing a fair amount of off-road touring in future.
    Or suggest any other DIY or not too expensive tower brace options that work with airbags?
    Thanks in advance, helpful thread.
  6. #14
    472 Post(s)
    G'day Marshall, I can absolutely agree that you need to tower brace Patrols before your big trip mate! My GU coily ute when purchased was top plate heading upwards so urgently straightened and installed a full ute plate 'Superior' bolt in job after finding. Mrs MB's GU wagon became my next concern as she tows horse floats so PatrolApart kindly installed a bolt in 'Boss Kit' Rossco on here ( @Rossco ) just bought what he believes to be near one of the last made 'bolt in' 'Boss Kits' on his current GQ project!
  7. #15
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I installed the Boss coil tower brace kit with Polyair bags last weekend. The brace kit doesn't change anything that might influence the air bag fitting.
    John
  8. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    00marshall (21st May 2017), MB (19th May 2017)
  9. #16
    194 Post(s)
    Quote Originally Posted by 00marshall View Post
    I have the spring towers fitted with the Superior Strengthener Kit and also have the towers tied together and bolted thru the floorpan - nothin' is going to move. I have the firestone in-coil airbags fitted and they improve the ride, but was still concerned about the direct stress into the coil tower mount, so have added a set of BOSS 3 rung external airbags. These work between the top of the diff housing and directly into the chassis rail, so no bending moment in play to start bending stuff. I use these in preference to the in-coil units now, however the ride is a bit of a 'wallow' if you put too much air into them to get an extended lift. Just a thought as these take the whole spring mount issue out of play provided the airbags are actually taking the majority of the load. The Superior kit is welded in, and this was the only downside as it was difficult to install on the garage floor situation. I like the idea ofthe bolt in kit especially with comments about them bein g able to pull a slightly bent mount back into position.
  10. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    00marshall (21st May 2017), MB (19th May 2017), Rossco (19th May 2017), threedogs (8th April 2018)
  11. #17
    472 Post(s)
    You're much more dedicated and skillful than me Philstar :-) Weld in jobbies on a ute with tray removed would be bareable but a wagon with fuel tanks/lines/body/...... all in the way would be a nightmare I reckon mate :-( Tower Bracing Coily's somehow is a dead set absolute must though at whatever cost we all reckon/agree for safety!
  12. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (19th May 2017)
  13. #18
    192 Post(s)
    Yeah just bought a Boss kit for the GQ, aparently their not making them anyone so I'd get in quick if you want some i reckon. Got mine from patrolapart and picked up the last set they had. Cost a few bob but look like a very nice kit, fully bolt in through factory holes - peace of mind is worth it 4 sure. . .
  14. The Following 3 Users Say Thank You to Rossco For This Useful Post:
    00marshall (21st May 2017), MB (19th May 2017), Stropp (19th May 2017)
  15. #19
    Patrol God Stropp's Avatar
    31 Post(s)
    I have the boss ones as well and installed them before the Simpson trip and have airbags and still have had no problems, well worth the money imho
  16. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    00marshall (21st May 2017), MB (21st May 2017)
  17. #20
    Wow really!! Damn will get on that
  18. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (21st May 2017)
