Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Water in my transmission
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    I was told that maybe I could try to flush the crap out with atf. And see if it will still drive and if it doesn't just to leave it be.
    Any thoughts
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    yes sometimes it works again by flushing it with atf. its worth a try but i wouldn't take it far from civilisation for a while. sometimes there fine but sometimes it just works for a little while if it works at all.
    done it with a couple falcon 4 speeds 50 50 if it works
  4. #23
    Dec 2016
    about to upload a photo of what drained of the trans and you can all tell me how fucked i am
  5. #24
    Dec 2016
    Dec 2016
    I'm going to try and flush out the water tonight with new tranny fluid and trans flush.
    Then fill up again and cross my fingers
  7. #26
    194 Post(s)
    Quote Originally Posted by JackCollo View Post
    I drowned a MB Gaelenaden wagen over the roof many years ago. The auto filled with water as did the rest of the vehicle. i managed to winch it out of the hole using a warn low mount and after a lot of effort, drove it home. I took it down to a local automatic specialist and had them do exactly as you are suggesting. The auto trans fluid was the colour of pink ice cream. The auto had just started to slip at this stage.
    Anyway, after a $400 bill from memory, the new fluid went in and no difference. the water reacted with the organic friction linings and it was a total rebuild - took it to MB and they refused to rebuild - only factory new. I went to an aftermarket reputable automatic reconditioner and it was never the same - vacuum advance on the auto just would not work, all new 'everything' - cost close to 10K. Lesson for me apart from being a dick and not testing the depth of the water crossing, was to not try and reco a transmission. I am sure many 'brown dog' transmissions have been overhauled with success, however i wonder about the finesse of the finished product. Mine was never the same and a disappointment, so I guess, just be aware you might be heading down a path or disappointment. The insurance wrote the vehicle off, which turned out to be a godsend as the dealers were out to extract every cent from a service - like driving down the road and throwing 'hundreds out the window'. So happy I bought the patrol after that.
  8. #27
    Dec 2016
    I have some good news. I filled the car up with trans fluid and liqumoly auto trans flush. And I was shifting through the gears and it jumped into gear in reverse and drive and I got a bit excited and gave it a bit of throttle and it drove forward. After filling it up I drove it around the block a few times and it didn't slip once just a bit rough but slowly getting better.
    Will drain the fluid and flush from it in the morning.
  9. The Following User Says Thank You to JackCollo For This Useful Post:
    4wheeler (2nd June 2017)
  10. #28
    Dec 2016
    Just a quick update. Had the transmission professionally flushed this morning and topped up with fresh fluid and drove like a dream.
    Just like it did before.
    Won't do anything to hard just yet and will nurse it back to its routine of trailer towing in due time.
    Thanks everyone for your help
