Page 965 of 1049 FirstFirst ... 4658659159559639649659669679751015 ... LastLast
Results 9,641 to 9,650 of 10488
  1. #9641
    472 Post(s)
    Looks Awesome Philstar
    Mark Mate:
    https://en.m.wikipedia.org/wiki/High...y_polyethylene
    We use it in laminated sheet form for play panels with CNC routed fun pictures/games.
    Many boats/tenders are starting to utilise molded HDPE too as it’s unsinkable and great for beach/reef landing smashing strength.
  2. The Following 2 Users Say Thank You to MB For This Useful Post:
    mudski (11th October 2020), PeeBee (11th October 2020)
    194 Post(s)
    Mark Mate:
    I cant find the reference re the HDMWPE - whats this for @MB, @mudski?
    MB (11th October 2020)
  6. #9643
    472 Post(s)
    Reference Mate?
  7. #9644
    461 Post(s)
    Highly Definite Marks Wise Pronunciations Exist?
  8. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Cremulator (13th October 2020), jay see (13th October 2020), MB (13th October 2020)
  9. #9645
    194 Post(s)
    HDMWPE - High Density Molecular Weight Poly Ethylene
    Good idea for the plate however needs a frame to support it. Also, its a lot thicker than the 4mm sheet, so you lose clearance.
  10. The Following User Says Thank You to PeeBee For This Useful Post:
  11. #9646
    Jun 2018
    24 Post(s)
    How did you bend those sheets out of curiosity?
    They look great, good job @PeeBee
  12. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (15th October 2020)
  13. #9647
    194 Post(s)
    They are two sheets welde together. The first sheet is flat and replicates the tank base. The second sheet is angled 8 deg upwards and the mount plate on the tow are is bent down 8 degrees. To do the bend without a press I cut a slot thru the sheet leaving 20mm at each end as a hinge. I then simply put the sheet in the vice and used a 15" shifter to bend it down. From there I fitted the tank sheet to the car, then mounted the tow bar plate, jacking the two plates upwards until they met. I then tack welded the two sheets together and left the car overnight as wanted a slow cool on the tacks for max strength. Next morning I unbolted the bash plate and then stitched a couple of temp braces onto the angled plate for total stability, then welded it out, ground out the braces and put the rubber sheet on, painted and fixed it in place. Bingo, all done!
  14. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (14th October 2020), jay see (14th October 2020), MB (15th October 2020)
  15. #9648
    Jun 2018
    24 Post(s)
    Ah I see! Great written description, makes perfect sense. Bending with a vice and large hammer is how I've been doing smaller projects, but the cutting with hinged ends is a clever approach
  16. The Following User Says Thank You to Cremulator For This Useful Post:
  17. #9649
    194 Post(s)
    Watched and learnt from many a tradie in the field!
  18. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (14th October 2020), MB (15th October 2020)
  19. #9650
    May 2016
    lower west victoria
    30 Post(s)
    He Didn't Mean With Paper Eric.
  20. The Following User Says Thank You to 10G For This Useful Post:
