Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Auto TRANS won't drive
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Rito boys and girls, my 3.0lt auto , backing out the driveway tonight it selected reverse and went backwards no worries , got out on the road selected drive and nothing happened, back in reverse and it moved slowly but not properly, back into drive & still nothing . Pushed it in off the road as it would not drive forward or reverse, checked the oil which was right & still clean , checked coolant level as I thought maybe it had pumped coolant into the auto and stuffed it but no, any ideas ? , about 2 weeks ago it shuddered slightly when I selected reverse, The auto fluid look fine in colour but as a precaution I changed it and the filter, has since done a full on 4WD trip up the bush and 1000 km highway travel with no problems , it's got me stuffed . The light still comes on on the little rocker switch for power/hold so I don't believe that to be the problem, selected 4WD on the transfer case lever and made no difference - the 4WD light came on the dash so any help/direction would be good 😳
    Jul 2016
    Worn clutch pack can allow the apply piston to over extend and pop the seal. Best bet would be a pressure test.
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Rito thanks , would that just go like that though ? Autos aren't my thing - I was a bit shocked when I took the pan off it the other day after I dropped the oil out and could see nothing except a plate with wires & plugs ha ha , I drive trucks for a living and have worked on them most of my life so I was unsure what I would see in the auto but expected to see more than that .
    Jul 2016
    Yes they can go as quick as that. Once that piston travels that little bit extra and let's the seal go, it's lost its pressure. Unfortunately I don't see an easy fix.
    192 Post(s)
    No good sprock, all the best with it, hope it's something simple. Yeah I'm the same, wouldn't have a clue about autos. .
    Jun 2015
    Heyfield Vic
    35 Post(s)
    I put Dextron 11 in it , just read on another thread on here that Dextron 11 will damage the auto and you should use the genuine Nissan oil , has anyone heard of this ?
  8. #7
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Quote Originally Posted by drz400y View Post
    Thanks mate , I'm flying blind here as I know nothing about them but I think I'm about to learn 😩
  9. #8
    Jun 2015
    Heyfield Vic
    35 Post(s)
    yeah thanks Rossco all I can here is kaching kaching kaching 💸
  10. #9
    461 Post(s)
    Shite Adam! I just picked up my phone and saw your text. Bad luck hey? I have no idea with auto's. Time to tow down to wholesale automatics and get a 4.8ltr 5 speed tip tronic auto chucked in. Lol.
    Hopefully its something simple though. Can you take the pan off these and have a gander? Not sure what you'll find though.
  11. #10
    49 Post(s)
    Sorry mate, but I think your up for a new auto.
    Had the same thing happen in a little 4 cyl wagon a few years ago, reversed into a cat park and that was it.
    I was told many years ago when changing filters in an automatic don't touch anything else as they quite sensitive.
    As for the type of oil, I don't think that it has to be genuine Nissan, but it does have to be the right type eg dextron 2 or whatever is recommended.
    Get on the phone and call a few transmission specialist see what they say.
    If you can pull it out you should be able to do a change over with a reconditioned one.
    Hopefully I'm wrong...
    Wouldn't be the first time.
    Sent from my XT1068 using Tapatalk
