Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 2013 GU ZD30 Carbon around turbo intake hose
    Expert Club 4x4's Avatar
    Blue Mountains NSW
    7 Post(s)
    so an update.
    Long story, but our truck developed an issue on the way back from the bash. It started on the leg from Windorah to Bourke it felt like i was towing a van, was having to push the truck along as it felt restricted and we had thick plumes of unburnt fuel out the back. A quick roadside check to ensure there were no leaks from the intake site - none to be found. I had cleaned out the air filter before we left Birdsville. Thinking i may have had a poor batch of fuel we put in some fuel conditioned and she was fine up until we got to Lithgow where it got worse than the prior stint.
    Long story short guys, upon pull down we found a hairline crack in the turbo housing, a bent oil return line, a filthy MAF sensor and the dreaded manifold leak from cylinder one.
    So - we've replaced the turbo, replaced the oil return line, blocked down the manifold and replaced all the studs and replaced the MAF sensor. At the same time we thought we'd do some mods for longevity and more power - so we've popped on a Cross Country intercooler and catch can, a 3 inch redback exhaust, plumbed up the pyrometer and upped the Steinbauer a little bit. What an amazing difference, no more soot or lag!
    Looking forward to getting it dyno tuned soon and documenting it in video and article form.
    I have to say, one of those roadside stops had me looking up threads right here on this awesome forum! what a great resource everyone here is :-)
  2. The Following 3 Users Say Thank You to Club 4x4 For This Useful Post:
    mudski (19th September 2016), Sir Roofy (19th September 2016), Touses (19th September 2016)
    what level is your engine oil,from what Ive heard
    they dont like being over filed, a little under is fine. lol
  5. #23
    Blue Mountains NSW
    7 Post(s)
    shes bang on at the moment and purring like a kitten
  6. #24
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by Club 4x4 View Post
    so an update.
    Lady luck must have been on your side that much heat
    and dirty M.A.F MUST have been close to blowing
  7. The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
    Club 4x4 (19th September 2016), Rossco (19th September 2016)
  8. #25
    Blue Mountains NSW
    7 Post(s)
    Quote Originally Posted by Sir Roofy View Post
    mechanical sympathy was the key!
  9. #26
    TRAFALGAR VIC
    35 Post(s)
    don't think so id check numbers 3 /4 injectors for damage or heat stress
    if the M.A.F was that bad you where well and truly over fuelling
    believe me mate detination happens even when you think everything
    is running normal it happened to me
  10. #27
    Blue Mountains NSW
    7 Post(s)
    A good tip. We actually pulled the injectors and checked them out, flow benched an ultrasonic cleaned them
  11. The Following 2 Users Say Thank You to Club 4x4 For This Useful Post:
