Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Brakes Problem
  1. #31
    Legendary dom14's Avatar
    38 Post(s)
    keep bleeding, when i did new master, lines and reco calipers on my gq it must have taken about 3 litres of fluid before all the damn bubbles were out and i had a good solid pedal
    Good to know that. Thanx mate.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Apr 2017
    Brake and clutch servo share the same vacuum pump and accumulator. I have had days of brake head scratching only to find my clutch servo needed a kit. If you don't have a vacuum gauge you can stick your thumb over the end of each pipe in turn where it plugs onto the servo. If it doesn't hold vacuum check for pipe leaks back to the pump. Its usually the front clutch servo seal that goes. Always bleed your brake apportioning valve first. I'm under one of mine today with no rear brakes.
  4. #33
    38 Post(s)
    Quote Originally Posted by ugandasafari View Post
    Welcome to the forum!
    I've had no idea they both use the same booster.
    It's apparently not the case with RB30, but I suspect TB42 & TD42 it is as above.
    Cheetah Outreach
  5. #34
    Feb 2012
    Camden, NSW
    Not same booster but a vacuum leak in one will effect the other.
  6. The Following User Says Thank You to Turtle_au For This Useful Post:
    dom14 (6th April 2017)
  7. #35
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    wait you guys have a booster on the clutch ? i must be the lucky one without it.
    but if the booster is leaking you should feel the pedal "push" back if you hold the brakes on then switch off the engine.
  8. #36
    38 Post(s)
    Vacuum Assist is the booster, is it?!
    Booster leak means a vacuum leak, isn't it?
    Cheetah Outreach
  9. #37
    38 Post(s)
    Quote Originally Posted by Turtle_au View Post
    Yeah, I can understand. "Sharing the same booster" doesn't make any sense.
    Cheetah Outreach
  10. #38
    Jan 2015
    19 Post(s)
    yeah the booster uses vacuum to assist the work you do to push the pedal.
    if the booster fails completely on a clutch makes the pedal like mine, booster fails on brake you have to push very hard on the pedal.
    if i remember right the booster should hold a vacuum at rest. you push the pedal and you let air onto the diaphragm inside and the vacuum behind it sucks/pushes the diaphragm making it easier to apply pressure to the master. surely if you google it someone would have made a neat little animation
    so yes it does mean a vacuum leak, but you could have other sources of leaks.
    it should have a check valve as well so if the engine dies you still have a bit of vacuum left to stop.
  11. The Following User Says Thank You to garett For This Useful Post:
  12. #39
    38 Post(s)
    I'm bit confused.
    Does the clutch booster do the same thing as the brake booster?
    Basically, making it easier to push the clutch pedal?
    In other words, failing clutch booster means harder clutch pedal?
    Cheetah Outreach
  13. #40
    Jan 2015
    19 Post(s)
    yes dom they are the same just different sizes. ( not saying the are interchangeable just they work the same way)
    but i would be surprised if a leaky clutch booster would affect the brake much. unless its a really big leak. never seen one i real life so speculating here.
  14. The Following User Says Thank You to garett For This Useful Post:
