23rd April 2020, 09:24 PM
#9451
PeeBee
Guys, was under the passenger side front dash area today and noticed the fan has come adrift from a heater box - I am guessing. What would cause this - the foam is perished, at the interface of the two boxes and everything appears firmly mounted.
Attachment 80926
Foam looks like its just perished. I think it would be quite easy to make up your own.
23rd April 2020 09:24 PM
23rd April 2020, 09:31 PM
#9452
See the part in red...
23rd April 2020, 10:26 PM
#9453
Easy peasy to get some slightly denser than normal foam and cut a gasket. Bin there, done that, Phil.
23rd April 2020, 11:13 PM
#9454
Many thanks guys, great bunch here. I was wondering if it could just fail, but I guess I have not been in it really since the rebuild began, I would not have noticed. I will have a look at the difficulty of getting a home made jobbie installed, however might ultimately default to a factory. Mark, is that pic from the overseas website or a local aussie buy from Nissan?
24th April 2020, 07:50 AM
#9455
Hey Phil, I think it is fairly comon for the foam to disintegrate with age. Mine was pretty shot when I did the rebuild just used some door sealing strip stuff from bunnings seemed to work well.
24th April 2020, 08:09 AM
#9456
PeeBee
That is from the Nissanfast program. The part number is at the bottom of the pic. I checked the part number and it seems to be discontinued. If you ring your local Ni$$an stealer and get them to check if there's any still available from any dealers.
24th April 2020, 08:12 AM
#9457
Rossco
I did the same with my GU when I had to change the heater core. I just used the door seal stuff from Bunnings as mine were pretty shot aswell.
24th April 2020, 08:26 AM
#9458
mudski
Thanks Mark, I have some 20mm soft draft seal so with shove that in and see how it goes.
24th April 2020, 09:57 AM
#9459
MB
Tested the old soft-roaders coils out this afternoon hauling a massive 2,000L of 78% N7, 21% O2 and a small mixture of some other crud :-)
Love that ute MB, looks great.
How come the tanks are on the tool boxes???
The Following User Says Thank You to 10G For This Useful Post:
24th April 2020, 11:11 AM
#9460
Was just being silly 10G mate.
Had to cart em home empty for Pony trough tanks.
