Was it a flat plug by chance? Really hoping to stick with a flat plug.
Yep, standard 7 pin flat socket, it is worth it for the LEDs that let you check that it is wired correctly without even connecting a trailer. On top of that it will make troubleshooting easier too
WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
That looks like it. There is enough room to run the standard trailer wiring plus a 25a cable. The screw down terminals are also big enough to accommodate the larger cable
