Page 46 of 105 FirstFirst ... 3644454647485696 ... LastLast
Results 451 to 460 of 1047
  1. #451
    194 Post(s)
    Quote Originally Posted by Mickhead View Post
    Seriously tho.. had a Rossi ebay inverter mig for a short time, sold it quickly due to horrid feed and lack of support. Rossi is an ebay brand that sounds nice.. like detroit and chicago trying to be milwaukee..
    OK, thanks for clearing that up - thought @MB had slipped into the thread! I will have a look at the Bunnings model instead.
  2. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    jay see (14th August 2020), mudski (14th August 2020)
    49 Post(s)
    Well after some googling and taking in the information from you guys and some of the guys at work. I'm pretty sure that I'm going to go with a 135 amp machine.
    Reason for this is the 2 people that have these are happy with them mudski (cigweld) and a guy from work(Michigan). Yes a bigger machine probably would be better, but I need to look at the cost as well, anyway if I need to do big long welds and I can't do them at home, I can always get it done at work.
    Thanks guys.
  5. #453
    330 Post(s)
    Thanks guys.
    Hi amte, i have a 140 too. if i was buying again i would go at least a 170 or 200 just to future proof me.
  6. #454
    461 Post(s)
    Tools you have bought/want to buy feedback thread
    Thanks guys.
    Happy for you to come over, post COVID, and have a play around with my weld if you want. The thing I like about mine it’s not confusing with it’s selections. Wire speed and output voltage selections. Does gaslless too but I have a Cigweld arc welder for that if I need. Bought the trolley on eBay for nix too. Like I said, for what I do and have done. 4wd stuff. It’s been flawless.
    Yeah a tig would be great. But I’d very rarely use that I reckon.
  7. #455
    49 Post(s)
    Thanks for the offer Mark, but I want one during this lock down period, probably get one during the week. I don't see the need for a bigger amp machine as long as these do the job and that's all I'm after. As stated earlier if it's a big long heavy weld I can get it done at work and even better by professional welder.
  8. The Following User Says Thank You to jay see For This Useful Post:
    mudski (16th August 2020)
  9. #456
    461 Post(s)
    Yeah we’ll don’t spend on what you don’t need then. Look on my build thread on the bar work I have done. That’s pretty much the heaviest I will ever do, probably the same for you I will guess, and this welder did it with ease.
  10. The Following User Says Thank You to mudski For This Useful Post:
    jay see (16th August 2020)
  11. #457
    472 Post(s)
    By no means a professional welder myself, agricultural at best Jaysee mate. Can offer only some basic advice until you hone your skills on any given machine, they are all different obviously but same same end game bonding metals at the end of the day?
    A good mask will help you focus on the material and what your heat/speed is doing left and right and downwards etc...
    There is no point making a perfect looking motion bead atop if the material below is not becoming one (Zen Like :-)
  12. The Following User Says Thank You to MB For This Useful Post:
    Mickhead (20th August 2020)
  13. #458
    49 Post(s)
    You'll be surprised how many times I see this at work when they are giving a new welder a test run.
  14. The Following User Says Thank You to jay see For This Useful Post:
    MB (16th August 2020)
  15. #459
    472 Post(s)
    That’s probably genuine I’m thinking though John Mate! Are they just getting a feel of the new tool before getting stuck into hot work.
    Not that I would trust myself to weld on say Vic/Roads approved engine mounts for serious scrutiny but I do try where possible to test my heat & speeds on similar sized plates prior to bastardisation of a paddock implement or two :-)
  16. The Following User Says Thank You to MB For This Useful Post:
  17. #460
    49 Post(s)
    They give them a few runs if they can't set the machine to produce a good weld in all aspects they move them on.
    Our work is ADR approved so they're gotta know what they're doing.
    I'll get some offcuts in different thickness to play around with at home before I attempt anything that requires strength.
  18. The Following User Says Thank You to jay see For This Useful Post:
