Page 1501 of 1651 FirstFirst ... 501100114011451149114991500150115021503151115511601 ... LastLast
Results 15,001 to 15,010 of 16505
  1. #15001
    Hmm, from a practical point of view, the ply is a quicker option, but you miss the opportunity to pack and straighten out any bows in the wall. Mind you, you have steel studs, so there shouldn't be any defects. Battens will be cheaper, but the ply also gives you more opportunities to fix the vgroove. Both ways have their merits, what do you think @MudRunnerTD
  2. The Following User Says Thank You to rusty_nail For This Useful Post:
    Bidja (21st December 2020)
    192 Post(s)
    Love the drop saw recessed into the bench bloody awesome, beats puuting it on the ground and packing up with bits of wood ! ! Really do like the timer gives a heap of warmth and character. .
  5. #15003
    330 Post(s)
    @rusty_nails Question that u may be able to answer.
    Started building my house yrs ago and stalled a bit due to health issues. Starting up again and has cypress T&G floor and going to put radiata pine lining boards on ceilings to steel joist /trusses and instead of battening it out thinking of fixing pine plywood sheet first and nail lining board to it or are timber battens the go?
    Cost and time consideration, thanks Nico_thinking of getting some local hired help as been too long finishing.
    Looks good mate, Too be honest i would Gyprock that all day. V Pine will be a fair bit of work but not crazy.. The metal studs should be straight and not bowed so no wall straightening required but you can't fix V Pine to them so you will need to batten them out with some 42x19 so you have some fixing for your lining boards. Buy a Brad gun if you are going to use Vpine though otherwise you are just doing way more work than needed.
    Obviously if you Gyprock it then you just screw the sheet straight o the studs. You will need Furring Channel to batten out the ceiling, again, if you are using vpine then you will need to batten out again to fix too. Furring Channel you just screw the Gyprock too it.
    If you sheet with Ply first then all your battening will be null and void so this may end up a cheaper option.. Again. Gyprock for the win in my opinion.
  7. #15004
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    @rusty_nail @MudRunnerTD thanks for feed back. Bit of a wood project along with wall construction of roadbase stabilised with 4% cement (rammed earth/no clay).
    The ceiling down below has raked section off flat and upstairs (loft) is as pic above. As mentioned, looking at getting some hired help to finish off internal fit out/lining, including the pluming/electrical. So with labour cost fixing v_joint on battens tending toward sheeting with ply first and then v-joint. Catching up with a builder tomorrow. Have done all except sheeting of roof (good lady and myself). Couple of pics.
  8. The Following 6 Users Say Thank You to Bidja For This Useful Post:
    Cremulator (22nd December 2020), jack (21st December 2020), jay see (23rd December 2020), MB (21st December 2020), MudRunnerTD (21st December 2020), TPC (21st December 2020)
  9. #15005
    Wow, looks great mate. I like the look. Well done getting to where it is currently, will look great when it's finished
  10. The Following User Says Thank You to rusty_nail For This Useful Post:
  11. #15006
    330 Post(s)
    That looks fantastic. I still think Gyprock would actually provide a great contrast to all your other textures. Colour on Gyprock (Even white) might just Pop!.. V Pine might actually clash with your floor a little. You might consider some higher quality face sheet ply and fix it up as a finished surface, that would give you the timber colour you are chasing and the 1200 x 2400 sheets would look great.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  13. #15007
    201 Post(s)
    Firewood collection is starting to look good. I have the week between Xmas and new year at home so will manage to double it again for a solid 2-3 seasons worth of stock.
  14. The Following 10 Users Say Thank You to Winnie For This Useful Post:
    Cremulator (22nd December 2020), Cuppa (21st December 2020), jay see (23rd December 2020), MB (21st December 2020), MudRunnerTD (21st December 2020), NissanGQ4.2 (22nd December 2020), PeeBee (21st December 2020), Plasnart (21st December 2020), Rossco (22nd December 2020), TPC (21st December 2020)
  15. #15008
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Oooooh yeah firewood porn 💦
  16. The Following 3 Users Say Thank You to Sprock For This Useful Post:
    MB (22nd December 2020), Rossco (22nd December 2020), rusty_nail (21st December 2020)
  17. #15009
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Nice work on the shed too Nicko
  18. The Following User Says Thank You to Sprock For This Useful Post:
  19. #15010
    193 Post(s)
    Deposit paid and block now ours at Wiseleigh, just outside of Bruthen Vic. Looking to building in 18 months and transition down there after that before retiring.wiseleigh 1.JPG
  20. The Following 12 Users Say Thank You to PeeBee For This Useful Post:
    10G (23rd December 2020), Bidja (23rd December 2020), jay see (23rd December 2020), MB (22nd December 2020), mudnut (22nd December 2020), MudRunnerTD (22nd December 2020), mudski (23rd December 2020), NissanGQ4.2 (22nd December 2020), pearcey (22nd December 2020), Plasnart (22nd December 2020), Rossco (22nd December 2020), Winnie (22nd December 2020)
