Page 130 of 187 FirstFirst ... 3080120128129130131132140180 ... LastLast
Results 1,291 to 1,300 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1291
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I wish. Nah not a chance unfortunately. I still have a fair bit to do and keen to drive this winter. Given the state of affairs with defects and Police these days it will most likely be a Night Drive car. Lucky I LOVE NIGHT DRIVES!!!
    I guess I'll just have to settle with photos then. One day I'll see it
    Lucus30's 1999 GU ST TB45E
  2. The Following User Says Thank You to lucus30 For This Useful Post:
    MudRunnerTD (2nd May 2016)
    Well been doing a bit of bar work, my nephew has been down to give me a hand as it's basically impossible to do alone. Coming together slowly.
    Pretty stoked with that!!
    I had to trim the door to clear the bar work. Ill sort that later.
    Pretty stoked with the way the rear bar is looking too.
    Just tacking everything up and will strip it all off to finish weld and paint.
  5. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Clunk (23rd May 2016), growler2058 (22nd May 2016), threedogs (22nd May 2016)
  6. #1293
    @ MR thats one of my Bush Hooks LOL
  7. #1294
    Yes it is mate. I have Kaned it to mate! Great bit of kit. Rate it highly! It has been my primary recovery point for 13 years.
    I will pack out a new hook the same way inside this tube. I like the hook as you can hook up in a hurry if needed.
  8. #1295
    Yeah that was the idea behind it, if your sinking you can hook up and hopefully be on your way again.
    Id think Ive made 5000 of them over the years, even have a bolt on one on the back of my Patrol.
    Like the pipe work BTW
  9. #1296
    Yeah when I drowned my GQ In 2003 the water was over the roof on the drivers side and upto the glass on the passengers side. I was using a pin only in the rear towbar and unfortunately my mate couldn't find the pin to insert the snatch strap in chest high water. By the time he hooked me up I was a writeoff. Had I had a hook the water inside would have been maybe to my knees.
    I bought your hook the following week.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  11. #1297
    43 Post(s)
    Not bad for a pen pusher... 😂
    JK.. it's looking awesome mate..
    One little bit I would add, and you maybe onto it or going vertical to your rack, but to give that rear 1/4 bar a little more strength add a bit of tube or plate to join the rear 1/4 to slider on the outside egde.. Sorta like a continuation peice. .
    That'll make a triangle and give a bit more strength against it..
    Sent from my SM-G800Y using Tapatalk
    @ MR Ive still got some spacers and that trimmed washer if you want to make it look a bit neater.
    Just PM your address if you require them
  13. The Following User Says Thank You to threedogs For This Useful Post:
    MudRunnerTD (22nd May 2016)
  14. #1299
    That would be awesome mate. I need 27mm of packer all up as it's obviously bigger than the one you made. I was going to cut up son plate I have here. Can you bring it to ABs next weekend mate?
  15. #1300
    Also 3Ds, you know that the @ is working again for notification but you can't leave a space like you have there. @threedogs is a winner though.
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (22nd May 2016), threedogs (23rd May 2016)
