Page 893 of 1049 FirstFirst ... 393793843883891892893894895903943993 ... LastLast
Results 8,921 to 8,930 of 10488
  1. #8921
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Over Boosting
    Thought I would put back in the positive pressure actuator (CRD) last night and with a bit of boot the VDO boost gauge went off scale at 30psi and could hold it there easily. Think something wrong with diaphragm/spring (factory spring set at 23psi) but EGTs were running good. Crawled home Tillix back in this morn.
    Glad I have gauges...
    Feb 2014
    Southern Tasmania
    Last weekend was the hybrid superflex arms to fix the castor angles in the front. This weekend was all about getting the rear pinion angle back to within spec with some superior adj uppers.
    What a mongrel it was to get those bolts back in with the shortened upper control arms. Thank god for ratchet straps and big screw drivers.
    Note: I could actually see daylight through one of the old upper control arm bushes!!!!
  4. The Following User Says Thank You to gazq For This Useful Post:
    rusty_nail (29th March 2019)
  5. #8923
    Jul 2017
    37 Post(s)
    Installed new radiator header tank, ordered from Patrolapart on Monday, arrived yesterday, was a long week and now installed (all good).
    Leaned on old tank overflow spout up the bush last weekend taking a short cut (changing turbo actuators) and busted it. Cautious trip home.
    At least I can now see the coolant more easily in the new one .
  6. The Following User Says Thank You to Bidja For This Useful Post:
    0-TJ-0 (29th March 2019)
  7. #8924
    49 Post(s)
    Nothing yet, but will have to see why it didn't start today. Completely dead, no power at all. Lights weren't left on and all doors were closed....
  8. #8925
    49 Post(s)
    No need to do anything, stupid thing started first shot.
  9. The Following User Says Thank You to jay see For This Useful Post:
    GQtdauto (30th March 2019)
  10. #8926
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Of course it did! The damn thing will be waiting for you to be way out in the sticks and all alone, and probably bogged. Then: click . . . click . . . nothing!
  11. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    GQtdauto (30th March 2019), jay see (30th March 2019)
  12. #8927
    194 Post(s)
    Quote Originally Posted by Brissieboy View Post
    Yep, agree. Check and keep checking until you find the loose wire or dud earth or faulty key tumbler, as it won't be funny out the back of nowhere-ville.
  13. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
  14. #8928
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Took the GQ out to get a load of wood on a gnarly little track called Sands track which is in the Mohyu Timber reserve , because it's so rough and steep virtually no one gets there wood off it so easy pickings .
    Got some photos of the result of last nights lightning storms on the phone but will post them up one day , we counted six trees that were hit and three exploded to leave about six feet sticking out of the ground the others were ringbarked in a spiral down the trunk with bits blown off all over the joint .
    Truly an amazing sight and all within a few hundred metres .
  15. The Following 3 Users Say Thank You to GQtdauto For This Useful Post:
    jay see (30th March 2019), Plasnart (30th March 2019), rusty_nail (30th March 2019)
  16. #8929
    That sounds pretty awesome, I would be very keen to see those pics mate.
  17. The Following User Says Thank You to Winnie For This Useful Post:
    GQtdauto (31st March 2019)
  18. #8930
    49 Post(s)
    The last time it did it, turned out to be a starter.
  19. The Following User Says Thank You to jay see For This Useful Post:
    PeeBee (31st March 2019)
