24th September 2015, 11:54 AM
Any thoughts on these ??
http://shop.snakeracing.com.au/exper...recovery-hook/
Anyone using one of these?
Or these
http://shop.snakeracing.com.au/black...ry-winch-hook/
Or this style
http://shop.snakeracing.com.au/red-p...tv-winch-hook/
Will save having that first foot being blasted by road grit all the time.
I covered mine in 3/4 split tubing
24th September 2015 11:54 AM
24th September 2015, 12:37 PM
I am he, fear me
First device I can see an application for the comp boys
The others?
Well, I don't use a winch hook anyway just attach my winch cable eye to the Bow shackle so using one of those just introduces another bit of kit and gives the manuf a hunjy or two
I spose the shear pin might add some safety then again maybe not... would kinda depend on the scenario
24th September 2015, 12:44 PM
The 747
the evil twin
Really? Seems like they would have to use a shackle which they don't like because they're too slow
25th September 2015, 07:58 AM
Patrol Guru
I have a very similar end on my winch rope which i simply attach a shackle through it to the tree protector when winching. Ill grab a photo of mine this morning for you.
I believe mine is actually spliced on and doesn't use a shear pin at all. The rope will break before the end comes off so it will still be secured to the shackle and tree protector.
The Following User Says Thank You to sooty_10 For This Useful Post:
threedogs (25th September 2015)
15th January 2017, 09:39 AM
Was wondering where to get those from
15th January 2017, 11:02 AM
FNqGu04
I have one that arrived with my Runva winch. Just search winch thimble on eBay there are a few including the Runva ones.
15th January 2017, 04:22 PM
@Hodge do you think its legal/safe sticking out like that ??
Certainly is one of the neater options out there
http://www.ebay.com.au/itm/Runva-Alu...EAAOSw44BYeqEX
15th January 2017, 05:02 PM
#8
threedogs
Don't know John, about legality. It isn't sticking out past the furthest front point of the b. bar.
15th January 2017, 05:13 PM
#9
Now that is a point, Pardon the pun. I would suspect it would be held flat against the bar by the rope pressure, would it not? It also eliminates the need for exposing the rope or cable to damage and UV rays.
15th January 2017, 05:19 PM
#10
mudnut
Yes it is held up against the hawse when the rope is taut. The black rubbery covers prevent it from sliding all over the place . Very neat.
The Following User Says Thank You to Hodge For This Useful Post:
mudnut (15th January 2017)
