20th May 2016, 08:11 AM
#6551
Patrol Guru
Looks like you are putting in the hours there mate. Great job you are doing there. Looking forward to the end result.
The Following User Says Thank You to blocko05 For This Useful Post:
nissannewby (20th May 2016)
20th May 2016 08:11 AM
21st May 2016, 05:59 AM
#6552
Started pulling bits off the motor ready for the head removal what am i gunna find will it be major or will it be minor stress levels @ 85% and rising
21st May 2016, 10:12 AM
#6553
nissannewby
So got the passenger arm done and back in and also torqued up. All my parts turned up yesterday. So turned up a press tool for the panhard bushes and rear control arm bushes. Picked up the injector pump last night as well. All going well I will get that in tomorrow night. Also tonight I replaced front panhard bushes, replaced front sway bar links and bushes, inspected and adjusted front wheel bearings and swapped the wheels over to the factory alloys with the new 265/75/16 Nitto terra grapplers.
Last night was kind of productive. Efforts were hampered by a seized stainless bolt that I had to cut with only a hacksaw blade. I did however get the newly powdercoated springs back in with new insulators. Replaced lower control arm bushes and bolts. This also meant the bent arm got changed out. Didnt get the pump on but I will hopefully get all the engine stuff sorted over the weekend. Will be good if its driveable by tomorrow night. Then it will be slapped on the dyno during the week to see what gains have been had.
The Following User Says Thank You to nissannewby For This Useful Post:
21st May 2016, 10:20 AM
#6554
The 747
Gonna be an awesome car now Mat, gonna be real hard to sell it now.
21st May 2016, 06:47 PM
#6555
Hung the front door from the shed roof , made doing the hinges so easy , and not have to disconnect any electrics
The Following 5 Users Say Thank You to gaddy For This Useful Post:
BigRAWesty (21st May 2016), blocko05 (1st June 2016), Stropp (23rd May 2016), Touses (21st May 2016), Woof (23rd May 2016)
21st May 2016, 07:00 PM
#6556
Will borrow that idea. I have to do mine.
21st May 2016, 08:09 PM
#6557
nissannewby
Not shown in the photo but i put a couple of zip ties around the strap either side of the top of the window frame , held it secure once the door was unbolted , all up about half hour job , and no more creaking noises when taking off .
The Following User Says Thank You to gaddy For This Useful Post:
23rd May 2016, 06:58 PM
#6558
So yesterday I got the rear upper control bushes changed and torqued up all the rear control arm bolts (bolts were also replaced). Then went about installing the pump. Installed it, timed it, hooked all the fuel and cables up to it and set the tps. Fitted the new injectors and plumbed up all the lines. Refitted the nice and clean intake manifold. Fitted a new water pump. Fitted new seals on vac pump and installed.
And today. Fitted new drive belts for the ac, power steering and alternator. Fitted a new fan. Externally cleaned the radiator and refitted it. Filled the cooling system. Refitted the batteries and bled injector lines up. Fitted intercooler and run and bled the cooling system. Took it for a drive. Will hopefully get out soon and tackle the wiring.
23rd May 2016, 07:00 PM
#6559
Sounds like you're aiming to get it on the road for the trip down this Fri/Sat Mat ? :P
23rd May 2016, 07:02 PM
#6560
Hodge
Haha. I doubt the patrol will be ready for that trip. Might have to fly and take a different car.
