Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: GU Patrol Barn Door crack repair guide
    461 Post(s)
    O.k So I have had a crack in my right barn door since owning the car. For those who don't know, the crack is caused by hanging a larger than stock tyre from the door bracket. The heavy tyre tries to pull the door outwards, hence, the window frame flexes just above where the frame meets the door skin and eventually cracks. Mine was cracked around half way through and hadn't moved, until I hung a 35 off it and it instantly cracked further. So something had to be done. Upon removing the inside door trim I had discovered that it was cracking on the inside too.
    I hunted around for a second hand door with no crack and the best I came up with was $400. No guarantees this door won't crack too...So I bought a Cigweld Gas/Gasless 130Amp mig welder for $350 and I will have this for other projects too...
    So gents here is how I went about repairing the crack. I am no expert welder and body repairer to I bloody hope it stays together.
    In a nutshell, I curved and slid up the inside of the door skin the RHS and plug welded it to the door...
    Tools you will need....
    • Mig welder
    • 25x25 RHS about 400mm long
    • 3mm x 25mm'ish flat steel about 800mm long
    • A Hydraulic press to bend the RHS or something else to do the bending
    • Drill and drill bits
    • Grinder and flappy disc to sand back the paint on the area to be repaired
    • Body filler
    • Spray putty / Primer
    • Paint
    • Plenty of time and patience
    • Welding skills, which I don't have
    • Body repair skills, which I didn't have either, Lol.
    Paint I used was just from SuperCheap. I gave them the paint code and they mixed up a spray can for me. I also got a can of clear for the final coat.
    1. Removal of parts
    • Inner door trimmings
    • wiper arm and motor
    • top locking mechanism and control rod
    • door catch
    • door opening handle and mech.
    • all wiring going up to the top of the door
    2. Preparation
    I went roughly 200mm either side of the crack and measured and marked it out on the door. Then proceeded to drill 8mm holes down the door staying in the 400mm length, on both corner edges of the door as you will only be able to weld to two sides of the RHS.
    3. Shaping the RHS
    This was quite tricky and took a while to get right. Luckily I have a cheap 12ton press I bought and its been money well spent i tell you. I used the press to bend and shape the RHS to the curve of the door.
    To make the RHS nice and tight in the door I welded the flat steel to the side where I was to weld to basically pack it out. After I did that, I was fitting, removing, fitting and removing to still get the contours right. This take a few good hits with a hammer to slide it up the door skin, getting it out was not fun, I had to use a long bit of steel down from the top of the door where the top lock sits to punch it out... Grinding the edges off the flat to suit the contour of the RHS. Finnally the RHS was pretty close. Well good enough for me. Lol.
    This is what the RHS looks like up inside the door...
    4. The welding begins.
    I forgot to take a pic of the finished welded door. Luckily I suppose as I as I ain't very good at welding. But all I did was slowly weld at the RHS and slowly filled the holes up with weld. Doing this slowly as I didn't want the door glass and rubber to get too hot. I had a wet rag with me and some water to pour over it just incase it got too hot. After a few welding sessions and then grinding sessions I thought it was good enough for me.
    Remember to mask up the back door glass, as I forgot and it copped a little grinding spray and pitted a small section of the glass.
    5. Bog and sanding time.
    This is another area where I don't shine but I had nothing to lose really and wasn't too concerned as you can see this section with the door shut. So the bog was applied, I waited for it to dry and sanded it back until I was happy with the result.Like my bog skills?
    One thing I found is I applied too much bog and didn't sand enough back. I had a though after I had painted it that there was too much bog over the cracked area and I knew the door would still flex a little. The end result was the bog cracked, so I just ran some white Sikaflex over it after the job was finished...
    I forgot again to take a pic of my final sanding job put here is a pic of the final spray putty before I painted it...I did four fine coats of spray putty with a light sand in between....
    6. Final paint
    I did around six very light coats with the paint, also with a light sand in between using 800grit sand paper. I could have used finer but thats all I had...
    Then four coats of clear to finish it off....
    Put all the hardware back in the door and then had beer!!!
    Hope this helps other out with their repairs...
  2. The Following 18 Users Say Thank You to mudski For This Useful Post:
    4bye4 (22nd February 2015), Badball (21st February 2015), Bloodyaussie (3rd June 2014), Bulbous (2nd August 2014), gaddy (3rd June 2014), growler2058 (22nd February 2015), LaughingBeagles (16th May 2015), mudnut (3rd June 2014), my third 256 (28th June 2014), ova50 (3rd June 2014), Parksy (28th June 2014), Rocket55 (3rd June 2014), Rumcajs (3rd August 2014), Sir Roofy (3rd June 2014), SonOf (17th April 2015), Stropp (3rd June 2014), Timbo15 (27th June 2014), TimE (3rd June 2014)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Very nice job mate !
    Don't forget the paint or rustproofing on the "inside" where you worked.
  5. The Following User Says Thank You to 04OFF For This Useful Post:
    mudski (3rd June 2014)
  6. #3
    461 Post(s)
    Quote Originally Posted by 04OFF View Post
    I could only go as far as painting the back sides ( the unwelded sides) of the RHS as you have zero access in there once the RHS is in and welded up.
  7. #4
    Brisbane,QLD
    12 Post(s)
    Im thinking, if you had perfectly good door, you could use Sikaflex to attach the extra support inside , may be enough to prevent the flex and so crack in the first place ?
  8. #5
    461 Post(s)
    Yes you definitely could I reckon. Or even drill into the inside of the window frame ( under the trimming) and screw it in. But the RHS needs to go in super tight so theres no movement. Or very little movement.
  9. #6
    brisbane
    Nice job mate that looks good! You could Spray some penetrol up in there with a straw fitting, it will make a flexible airtight film to prevent rusting, great for hard to reach areas I love the stuff.
    http://www.bunnings.com.au/flood-300...aycan_p1560172
  10. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    mudski (4th June 2014), Parksy (28th June 2014)
  11. #7
    Jun 2013
    Great post Mudski, I will be doing the same repair shortly. Do you believe that you have created enough strength for the door to carry a rim and 33" tyre, I'm going to try anyway but just thought I would get you opinion as I don't have the money to buy a wheel carrier and don't want the extra 100kg weight that comes with it either.
  12. #8
    A 33" and rim would weigh around 40kg I would think , you could do what Ive done and mount the spare internally
  13. #9
    461 Post(s)
    Quote Originally Posted by brimon View Post
    Thanks....
    I have a 35inch on the door and it's holding great.
  14. #10
    Dysart Qld
    did you disconnect the battery when welding? probably silly question
