Results 1 to 6 of 6
Thread: Gq to Gu axle swap what rims/ off set to use ?
    Expert First Pooy's Avatar
    Mar 2018
    Talking Gq to Gu axle swap what rims/ off set to use ?
    I am doing a front and rear axle swap rotors to rotor, I was told a 15 inch with a -40 off set another said 16 inch 0 offset so what is it ? I want to put 35s on
    461 Post(s)
    If you use neg 40's the wheels will be sticking right out. I believe you even need to add some rubber flaring when using neg 13's. Not sure, you might even have to give the guards a trim so the 35's dont hit the guards. @AB @Winnie. You guys would know more about this.
    Yeah the 35s will require a bit of choppy choppy to the guards.
    -44 on the GU diffs would be super wide! I am running 33x12.5 with the factory flares on -22 rims with the GU diffs and they stick out a fair bit.
    Mar 2018
    Well my be one day 35s but the 4 inch lift might look a bit funny on 33s, so can my 33 12.5/ 15 fit on a Gu axle I think they are -20 something sunnnys how do you tell ?20190316_213052.jpg20190316_213026.jpg
    Quote Originally Posted by First Pooy View Post
    Yeah they will fit unless you have the TB48 brakes. They may stick out a bit though.
