Results 1 to 5 of 5
Thread: Fat Airbox?
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    Fat Airbox?
    Hi All.
    I know these are most often on a TD42 motor - but has anyone been able to install a Fatz Box on ZD30 CRD? I know this would mean some way to deal with the MAF ...
    I'm just curious. Fat are saying is doable. But it's a chunk of money so I don't want to discover after it arrives that it won't fit and won't work...
    I have a stock Nissan Snorkle. Fatz are saying that's fine - I would just need to cut out the hole in the guard to 4".
    Thoughts? I you have managed it on a ZD30 - how is it?
    Ta!
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
    43 Post(s)
    It can be done.
    Simply cut the square flange off the front of the maf housing and place a bit of silicone tube between the air box and maf housing..
    Not recommended though for Di as the maf sensor is pretty critical and the inline filters / mesh screens soften the air over the maf.
    Crd doesn't seem to be as touchy but you may get some limp issues with maf voltages spiking under hard acceleration..
    Nothing a remap can't fix though..
    Sent from my SM-G800Y using Tapatalk
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Boinzo (13th April 2017)
    just a thought when I was upgrading my air intake, was told
    incorperate a "hump" silicon hose into the system just saying
    Dec 2015
    Brisbane
    What the hell is that mate? Sounds dirty....
    Also - what did you end up with Threedogs? I know you did a lot of investigation. What has been your results? Any improvement in economy?
    Ta!
    Quote Originally Posted by Boinzo View Post
    Ta!
    Havent been well enough to fit it, I have a spare MAF here I'd like taken out a bit.
    But one from an Opel fits just check ebay cheaper than say HPD doing the same thing,
    You'll see those silicone hoses with a hump on them, suppose its for surges etc
    just type in silicone hump hoses on Ebay,,,puter playing up for link
    finally worked http://www.ebay.com.au/itm/Silicone-...XSzdDZTHcqHrVA
  8. The Following User Says Thank You to threedogs For This Useful Post:
