Page 1344 of 1450 FirstFirst ... 34484412441294133413421343134413451346135413941444 ... LastLast
Results 13,431 to 13,440 of 14491
  1. #13431
    461 Post(s)
    We can fix that guard together no problemo Mark Mate! Could be a good thing, reckon I’ve got some thin flat plate strips hiding in the shed that could assist
    Thanks Mark. I’ll see if I can either, get the rims swapped, or see what shorter axles there are first.
    MB (21st February 2021)
    194 Post(s)
    Yeah just too much happening in life at the moment and trying to cram everything into my inadequate brain right now isn’t working. Work is crazy busy, extension going on and things we have to do on our part for the extension, helping out my elderly dad, two chainsaws need repair before the cutting season starts, plus the trailer, kids want/ needs stuff done also. Wish I could just click my fingers and have it all done.
    Another thing that peeves me off.... welding upside down! Gawd! I run a few test welds to get the mig settings right. Do this, my welds are spot on, then climb under the trailer and I’m welding like I spaz! I gave up in the end and just accepted that this is how they are going to be. Spatter burns are great too.
    Today has NOT been a good day.
    Mark, you may have quite easily got the mig wire sheath on too tight a bend radius and it would not feed correctly - been there numerous times trying to squeeze under the car and get the gun aligned correctly, jump out, test weld again, all good, back under, cocky shit.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (21st February 2021), mudski (21st February 2021)
  6. #13433
    461 Post(s)
    Quite possible mate. I probably should have pulled the old arc welder out in hindsight.
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (21st February 2021), PeeBee (21st February 2021)
  8. #13434
    472 Post(s)
    Flip IT
  9. The Following User Says Thank You to MB For This Useful Post:
    jay see (21st February 2021)
  10. #13435
    192 Post(s)
    Yeah ther difference in welding where your nice and comfortable vs upside down contosionist with ya helmet wedged between an axle is quite substantial. . At least no one wil lie under there and criticise hopefully . . .
  11. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (21st February 2021), mudski (22nd February 2021)
  12. #13436
    461 Post(s)
    Flip IT
    Trailers to heavy for little me to flip. I thought hard about how to flip it and it just too heavy.
  14. #13437
    Are you doing your test welds upside down? You will need different settings when welding upside down compared to horizontal down hand.
  15. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    MB (21st February 2021), Mickhead (24th February 2021), MudRunnerTD (21st February 2021)
  16. #13438
    461 Post(s)
    I did not know this, but it makes sense. Gravity will want to pull the molten metal away from where its supposed to go. Too late now...
  17. The Following User Says Thank You to mudski For This Useful Post:
    MB (22nd February 2021)
  18. #13439
    May 2016
    8 Post(s)
    up the voltage do it in short blobs . you need plenty of throttle! I hate overhead welding but always end up with a bit to do .
  19. The Following 2 Users Say Thank You to Tip12345 For This Useful Post:
    MB (22nd February 2021), mudski (22nd February 2021)
  20. #13440
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Bloody Optus. Always no signal when you need your bloody mobile to make and take calls at home....why do we have to pay for no service times?
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  21. The Following User Says Thank You to Truckus For This Useful Post:
