Results 1 to 10 of 16
Thread: Power
    Aug 2018
    Power
    Ok lads question obviously this will vary, so with 3 inch straight thru exhaust stock turbo gu black top what power figures can I expect on tune?
    No inter cooler yet.
    581 Post(s)
    Power
    Varies a bit mate but maybe expect around the 90 - 100 ish rwkw?
  4. The Following User Says Thank You to AB For This Useful Post:
    MB (5th September 2018)
    Aug 2018
    Alright thanks for heads up 👌
  6. The Following User Says Thank You to Drifty3@hotmail.com For This Useful Post:
    Dads GQ (12th October 2018)
  7. #4
    473 Post(s)
    Unfortunately never had the pleasure of an intercooler either Drifty on our TD42T’s. 3” exhausts and decent tunes too have also been as far pimped ever. Does give better fuel economy and some say at best 20% power increase from stock although please do buy an EGT guage and drive your beast off that. Newfound power you’ve aquired mate will see your exhaust temps climb beyond 550C if hauling too hard uphills.
  8. #5
    Aug 2018
    Oh yeah for sure an EGT is going in with new exhaust and tune wouldn’t live without it. Any recommendations for a place to tune the big girl at?
    North of bris pref or in bris
  9. The Following User Says Thank You to Drifty3@hotmail.com For This Useful Post:
  10. #6
    473 Post(s)
    Not sure mate, well south of two Aussie borders I’d be down here in Mexico :-)
  11. #7
    473 Post(s)
    Worth considering a 4” snorkel system too mate to get that higher cooler ground air into your big old diesel compressor without IC. If money is tight they can be done for only a few hundred bucks if you check out AB’s build thread early days advice.
  12. #8
    Aug 2018
    How many extra tacos would she put out if I added a cooler with what I said above?
  13. #9
    473 Post(s)
    Quote Originally Posted by Drifty3@hotmail.com View Post
    It does get a fair bit deeper than that mate and you are living within a State surrounded by the best of the TD42 builders.
    Quite simply from what I’ve hopefully learnt is that crisper air in mixed with perfectly pressurised ratio fuel fast out = serious power.
    My near stock setups have always found EGT’s somewhat 30% ish at least higher and power near 50% less of what could big dollar safely be achieved if you need mate!
  14. #10
    Aug 2018
    Yeah even that much figure increase seems tasty, to find a well recommended place now
