Page 794 of 1049 FirstFirst ... 294694744784792793794795796804844894 ... LastLast
Results 7,931 to 7,940 of 10487
  1. #7931
    194 Post(s)
    Pics please Phil!
    Not much to see, simply 3 off storage trays to hold recovery gear, tools and misc parts. Spaces the original setup 'up' 170mm, so now an excuse to look at a drop down fridge slide perhaps. DSC01787.JPG
  2. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (12th September 2017)
    194 Post(s)
    Went down to nissan spare parts to get a handfull of screws for the headlight surround - not in stock, come back at 2pm. Came home, moved truck out of garage and it 'stopped'. Searching around, no fuel, bled the system using the boost pump and hand pump, no fuel. Under the car, checked the newly installed fuel filter, all full, boost pump not sucking it thru. Bypassed the new filter, primed the system with boost pump and hand pump, runs like normal, so my super duper extra fuel filter is too much for the boost pump, so that great idea has gone out the window, unless I put another booster pump between the tank and the second filter. Right now, annoyed, filthy and stinking of fuel, just finished cleaning everything up and noticed an oil witness mark between the engine and gearbox adapter plate which looks like a seal is leaking - shit.
    Got the screws and at $26 for a pack of 10, they did the job, considering I only needed 2.
    Had enough of the car today, retreated inside and licking my wounds.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (11th September 2017), MB (12th September 2017)
  6. #7933
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Not sure where to put these pics but my new air cylinder, courtesy of some idiot dumping a heap of them out bush .
  7. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    BigRAWesty (11th September 2017), MB (12th September 2017)
  8. #7934
    175 Post(s)
    Quote Originally Posted by gubigfish View Post
    Be interested to know how much that affects the cooling @Hodge approx how much for the fan?
    Thought I'd share experience so far.
    It made a difference , but a negative one. I'm unsure why.
    Temps are 1-2C higher than usual. Before fan swap idle for example always settled at 76C , now it's 77-78.
    Driving around town and crusing on highway is the same. Usually sits 78-79 cruising at 100kmh . Now it's 80-82.
    I'm unsure why ...
    Fan is the right way around. @mudski @gubigfish .
  9. The Following User Says Thank You to Hodge For This Useful Post:
    gubigfish (11th September 2017)
  10. #7935
    43 Post(s)
    That my friend is a bloody good idea!!
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
  12. #7936
    461 Post(s)
    I'm unsure why ...
    I noticed this when I did mine. I've been thinking a lot to why. I came to the conclusion which I think is plausible. Try and see where Im coming from, a bit hard to explain. The new fan draws more air. So the new fan will use or need more turning force. The stock hub is only designed for the stock fan, the new fan on the stock hub, wont spin at the same rate as its "heavier" on the hub. Hence adding more oil the hub to make the fan spin.
    When I did mine.
    The first time it was, new fan on OEM hub. Pretty much zero difference. I then spent a while trying different amounts of oil in the hub until I was satisfied with the outcome. After the third shot. I found a happy medium.
    So just using this fan and not doing anything else, has proven it does jack ship. More needs to be done for it to be effective.
  13. The Following 4 Users Say Thank You to mudski For This Useful Post:
    GQtdauto (11th September 2017), Hodge (12th September 2017), PeeBee (11th September 2017), Rossco (12th September 2017)
  14. #7937
    175 Post(s)
    Definitely know what you mean.
    Larger and more aggressive fan means the hub will "slip" more due to more load on it and not spin the fan at the same rate as the lighter fan ...
    So time to mess with some hub oil.
    You suggest I start taking some oil out bit by bit ? Is that how it works less oil more grip ?
    @mudski
  15. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (12th September 2017)
  16. #7938
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Tested out the air tank , was able to get from 15psi to 25psi in about 15 seconds and that's with a chunky 33" muddie so thinking a double tank setup could be the go .
  17. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    BigRAWesty (13th September 2017), MB (12th September 2017)
  18. #7939
    461 Post(s)
    @mudski
    You need to add oil. I ended up using 2 1/4 bottles until I was satisfied.
  19. The Following User Says Thank You to mudski For This Useful Post:
  20. #7940
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    put a new clutch master in as the old one had been leaking since the licola trip.
  21. The Following 2 Users Say Thank You to garett For This Useful Post:
    MB (13th September 2017), mudski (13th September 2017)
