3rd September 2017, 11:08 AM
#7911
Rossco
Did you find it?
yep....she just need a better bra
The Following User Says Thank You to Avo For This Useful Post:
Stropp (3rd September 2017)
3rd September 2017 11:08 AM
7th September 2017, 09:43 PM
#7912
Finally got the fuel consumption flow meters installed and working, however the double Dutch Romanian inverse instructions for setup are doing my head in. Trying to set it up for lph instead of ppm isn't playing the game and struggling to set the parameters so the flowratezeros each time the engine stops. More time on the phone tomorrow with the agent to try and resolve.
Also made a couple of stainless steel storage drawers for tools and recovery gear that go under the existing rear storage setup, will post pics when it's finished. This should take a heap of stuff from the back seat
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
GQtdauto (9th September 2017), MB (8th September 2017), mudnut (7th September 2017)
8th September 2017, 08:19 PM
#7913
Today was day 1 of converting the 3ltr to a 4.2 happy days
Sent from my SM-T530 using Tapatalk
The Following 6 Users Say Thank You to morton2478 For This Useful Post:
AB (8th September 2017), Avo (8th September 2017), GQtdauto (9th September 2017), Hodge (9th September 2017), MB (8th September 2017), Rossco (9th September 2017)
9th September 2017, 06:48 AM
#7914
Administrator
Are you starting a build thread mate?
9th September 2017, 03:19 PM
#7915
Fitted up the infinity fan to the motor.
The Following 3 Users Say Thank You to Hodge For This Useful Post:
GQtdauto (9th September 2017), gubigfish (9th September 2017), Stropp (10th September 2017)
9th September 2017, 03:28 PM
#7916
Be interested to know how much that affects the cooling @Hodge approx how much for the fan?
9th September 2017, 04:58 PM
#7917
gubigfish
Will be interesting to see too mate. Most people who have it, have said it performs better. Can instantly tell it pushes air more and you can actually hear the whir of the fan, much more noticeable than the original. My motor doesn't overheat, nor do I tow or push it too much so, I don't know how it will perform at mostly idling temps, compared to say somebody whos got it fitted and does a lot of towing and the temps are on the higher scale.
It cost me around $120AUD shipped from UAE. Thats using https://partsouq.com/ which nissannewby put me onto. Ive bought a few parts from there and saved a ton compared to anywhere local and shipping is fairly fast too.
MudRunnerTD (24th September 2017)
9th September 2017, 10:36 PM
#7918
gubigfish
I found pretty much zero difference just running the fan of a stock, unmolested fan clutch. only when I added more oil in the hub I saw any cooling change. But a better fan to have none the less.
10th September 2017, 05:01 PM
#7919
Yes I paid $450 with the bigger hub and fan from ufi made a lot of difference, you can actually hear it.
The Following 2 Users Say Thank You to Stropp For This Useful Post:
gubigfish (10th September 2017), Hodge (10th September 2017)
10th September 2017, 05:18 PM
#7920
Finished the majority of the rear setup today, just a door to make tomorrow.
Swapped out the HID headlights for LED Globes, running thru a Piranha headlight loom. Keen to see the difference, globes only, not the headlights - when they tone down the design to stop them being easily recognisable i will probably swap over to them.
