Results 1 to 9 of 9
Thread: Best intercooler for 230whp application. Td42ti
    Mar 2017
    East Kimberley, WA
    G’day all,
    I’m the market for a new intercooler. Thinking W2A
    As I don’t want to cut the bonnet. What has worked best for a
    230whp application, my engine has a new style UFI Td05-18g and DC6 fuel pump fitted.
    (2006 Gu patrol Ute) currently running a 600x400x75 FMIC, works extremely well
    But I have noticed some pinholes and I get nervous about the winch punching a hole in it out
    Bush if I smack a roo hard enough.
    Have got a quote in a 4x8” PWR tube style for roughly $1600,
    They claim 290hp/390cfm capacity.
    Thanks for your help/advice in advance!
    May 2016
    8 Post(s)
    Do yourself a favour put an out front one .. It does not suffer from heat soak ..
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Frozen Boost ex USA less than $300.00 good for something like 600hp.
    Tractor aircon radiator thingy, two 10" CraigDavies fans under. 80lt pm elecy pump.
    No more than 2deg difference one side of IC to the other.
    Less than $1200.00 all up.
  5. The Following User Says Thank You to Touses For This Useful Post:
    Norwest4.2 (11th April 2018)
    Mar 2017
    East Kimberley, WA
    Looks good Touses!
    Is that a 10"x4.5"x4.5" ?
    Thanks mate!
    Mar 2016
    Childers QLD
    22 Post(s)
    Quote Originally Posted by Norwest4.2 View Post
    Looks good Touses!
    Thanks mate!
    It's the type 10 12.5x12.5x4.5
    Be aware tho I 'had to lift the body by 25mm to get the bonnet to close with enough clearance for tourque roll. Missed by that much 99 !
    22 Post(s)
    G’day all,
    390 cfm is barely enough air for a naturally aspirated TD, let alone a TD42t with some real boost. The PWR barrel type W2A is less than Ideal.
    The frozen boost stuff isn't the best on the market, but it has been used plenty of times with success and is good value for money.
    You could go to the top shelf and get an A.R.E w2a, but they cost $5k.
    A decent w2a or a decent front mount is the way to go.
    96 GQ coil/Cab
    08 G6eT
    Mar 2017
    East Kimberley, WA
    Quote Originally Posted by Touses View Post
    Thanks for the info mate! much appreciated.
  10. #8
    Mar 2017
    East Kimberley, WA
    Thanks for the info mate, alarm bells were ringing when i looked over the quote from PWR because it was soo generic! they don't specify an application for the product (diesel/petrol/conditions etc) just a 'hp' rating. I think i will just replace my current intercooler with the same again... its done alot of k's of hard off roading, wear is to be expected i suppose. Have you used an A.R.E cooler yourself? i haven't heard a bad thing about any of their products!
  11. #9
    22 Post(s)
    I have an A.R.E W2A, had it for about 6 years. It's very well made. The pic is in my signature
    96 GQ coil/Cab
    08 G6eT
