28th March 2018, 08:39 PM
#21
28th March 2018 08:39 PM
28th March 2018, 09:13 PM
#22
Administrator
Nah you don't need to spend that much on a full kit. You just need a straight flange and get hose and clamps from local autobarn, supacrap or repco.
I would personally get a straight flange and it just needs to suit a 51mm bolt spacing.
Something like this but have a search on EBay and maybe measure the vertical distance from turbo to block drain to make sure there's enough distance for the hose to do a nice even curve to your block for smooth drain and minimise sharp 90 degree turn of pipe so it doesn't kink if that makes sense.
https://m.ebay.com.au/itm/Turbo-Oil-...-/301682866510
28th March 2018, 09:14 PM
#23
Administrator
Barb style oil drain flange.
28th March 2018, 09:16 PM
#24
AB
You are too awesome.
Thankyou.
I ordered this. My mate needs a feed line. I need the drain line.
https://www.ebay.com.au/itm/MAMBA-Tu...UAAOSw0hRZcZBz
28th March 2018, 09:18 PM
#25
Administrator
Awesome that'll do. Make sure your mate pays $100 and you pay $22 lol
28th March 2018, 09:19 PM
#26
Not to much crankcase pressure it's not breathing a bit hard ? Blocked engine breather
The Following User Says Thank You to Tip12345 For This Useful Post:
28th March 2018, 09:22 PM
#27
Administrator
Yeah my thoughts too Tip...
28th March 2018, 10:16 PM
#28
Tip12345
Sorry i dont understand. Where is the engine breather? It has an oil catch can. Not much blow by.
28th March 2018, 10:23 PM
#29
Is it that round thing at the back of the rocker cover.
How do i clean or unblock it
29th March 2018, 08:31 AM
#30
Just remove the oil cap when running and see now much pressure its blowing out
