28th November 2016, 11:43 PM
Something loose
Had a bad rattle under dash after a light off road trip, well today I found this thing loose lucky I found the nut and bolt and now it's tight again. Question is what is it? Also could this be the reason for my tacho jumping?
28th November 2016 11:43 PM
29th November 2016, 07:41 AM
Going by the part number it seems to be a control module for the injectors. Whether this is linked to your issue? Not sure. Is your tacho jumping now?
29th November 2016, 10:31 AM
mudski
Thx mud
Went for a drive on smooth road and had hardly any rattle prior to finding it loose with no tacho problem but I know when I drive to work there are some rougher roads so hoping this may have been the problem, stay tuned.
The Following User Says Thank You to Pj-14 For This Useful Post:
mudski (29th November 2016)
1st December 2016, 02:03 PM
Had a good day out to McMahons lookout in Wentworth Falls and then over the mountain to Wheeney Creek and not oncedid the tacho bounce nor the engine light come on so hopefuly mystery solved. Getting a full check up today and if all comes back good then upgrades will be coming.
The Following 2 Users Say Thank You to Pj-14 For This Useful Post:
mudnut (1st December 2016), mudski (1st December 2016)
1st December 2016, 02:21 PM
Good to hear you have found the culprit.
