Page 959 of 1049 FirstFirst ... 4598599099499579589599609619691009 ... LastLast
Results 9,581 to 9,590 of 10488
  1. #9581
    472 Post(s)
    Can’t complain, some 25+ years out of a GQ TD42 viscous hub has finally dropped her guts!
    Bit the bullet and went against my OEM preferences usually and we’ll try out one of these UFI aggressive kits from Patrolapart.
    Must say, first impressions are it does appear to move a fair bit more air than the old OEM when it was working before its unfortunate blowout on the old faithful clacker.
    https://youtu.be/cJ_TlcRC03E
  2. The Following 6 Users Say Thank You to MB For This Useful Post:
    0-TJ-0 (18th August 2020), 10G (18th August 2020), Cremulator (19th August 2020), mudnut (19th August 2020), Rossco (18th August 2020), Yeti's Beast (20th September 2020)
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I got similar from quikazz. Love it but I do wonder what temp the hub actually kicks in at.. Mine seems to come in at about 85 but I think my stat is a 90.
    I wonder what the balance there should be. Should the stat open first or the fan spin up? In my head the stat should be cooler than the fan start temp for best fuel economy.
  5. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MB (18th August 2020)
  6. #9583
    472 Post(s)
    Your logic makes good sense to me too TJ Mate! Unsure what the coupling here from UFI fully kicks in at but I’m running an 82C OEM thermostat in this old girl these days.
  7. #9584
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
    Did you get to the big in the block when you drained it,it is on the left hand side between cylinder 5 and 6 I think from memory,when I did ours I flushed it a few times...
    Yeah the Turbo is plumed in there so I just pulled the water hose off the bottom of the turbo to drain the block.
    Gave it another flush leaving the flush solution in overnight without the rad hooked up and got a little more out.
    Now to see if I can get the thermostat housing threads fixed.
    Edit: Ok striped threads in the thermostat housing have been fixed the 8mm bolts have been replaced with 10mm, the two short bolts are stainless while the long bolt was only available in hardened steel.
    Not my handywork but that brings a end to this rad flush.
    Had to top up the water once during the 15k drive into the Rochester service center at 30-60kph and the water had stopped circulating again for the last km so just made it without a tow.
  8. The Following 2 Users Say Thank You to Dasa For This Useful Post:
    10G (19th August 2020), MB (20th August 2020)
  9. #9585
    194 Post(s)
    Purge day today inside the truck. I needed to empty the barge in order to run the new camping light switch cable to the rear. I wasn't totally surprised at the volume that came out, but now the task is to see if i can reduce it before getting it back off the garage floor.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (26th August 2020), Mickhead (26th August 2020)
  11. #9586
    Expert Mickhead's Avatar
    Oct 2019
    0E8F47BA-8D0F-4E12-8B58-B05C1B5F311F.jpegAfter about 3 fails I think my “no cut wires “ Glow plug timer is working... Still waiting for my ebay cz258 glow plugs to arrive. 802B403D-ABC0-4AE1-906B-5DE37519328A.jpeg
  12. The Following 3 Users Say Thank You to Mickhead For This Useful Post:
    10G (25th August 2020), MB (26th August 2020), PeeBee (25th August 2020)
  13. #9587
    May 2016
    lower west victoria
    30 Post(s)
    Lotta rope there Phil, coupla spare head rests as well by the looks...
  14. The Following 2 Users Say Thank You to 10G For This Useful Post:
    MB (26th August 2020), Rossco (25th August 2020)
  15. #9588
    194 Post(s)
    Never have too much rope! I carry 180m plus the 30 on the drum. Recovery activities are not always straight forward as you know, and have been caught on a few spur tracks where the vegetation is very light and descent anchors are out well past the drum capacity. I days gone past this sort of length in wire rope was a physical impossibility, but now the weight reduction only makes the storage an issue - concentrating on that now. Head rests are off the rear seats
  16. The Following User Says Thank You to PeeBee For This Useful Post:
  17. #9589
    Oct 2019
    Mate.. you could lose a whole 150 grams by dumping one of the thermostats, and I am really curious about the welding glasses too...they will give interesting sun tans
  18. The Following User Says Thank You to Mickhead For This Useful Post:
  19. #9590
    194 Post(s)
    I dont like zucchini so use them when I am in the solarium getting my full body tan worked on. Perfectly natural thing to do when in lockdown I believe. The truck uses 2 thermostats and these are low temp units so by default are lighter in weight - I am keeping them in. Thank you for your considered assessment.
  20. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (26th August 2020), Mickhead (27th August 2020)
