9th October 2016, 08:24 AM
#11
Ok. I guess I just need to install it an see what happens. Hopefully I don't get boosting problems. My exhaust size is standard so maybe people get different results with other mods.
As for chipping it. Is there a chip that improves fuel efficiency? If so, what do you recommend and how hard is it to DIY? (like for a dumb person )
9th October 2016 08:24 AM
9th October 2016, 10:03 AM
#12
I had no issues with a full egr block and stock exhaust.
Disconnect the battery while you do the mod and it'll reset the ecu.
Not sure if they relearn things but yea I had no issues..
Only had issues since 3" exhaust has gone on..
9th October 2016, 11:05 AM
#13
Thanks bigguwesty. Seems the 3" upgrade throws things out of wack.
The Following User Says Thank You to azzacalabaza For This Useful Post:
BigRAWesty (9th October 2016)
9th October 2016, 07:31 PM
#14
Hey azza sorry for the late reply yeah I did the Maf sensor and disconnected the battery I was getting about 500 kays out of the main tank after the block,and roughly 600 before. I just installed Dawes valve set up( thanks mudski) and put a 3 inch DEA system on in the last few weekends, I went camping last night and did some driving around and so for I have gotten 650 from the main and still have a bit under a quarter of a main tank left
The Following User Says Thank You to ThefattymattymkII For This Useful Post:
growler2058 (9th October 2016)
9th October 2016, 07:40 PM
#15
I had just the block as the sole mod and had it that way for about 7 months, I have the cheapo EDS from 4wd supa centre to clear the codes, it wasn't till I installed a boost gauge that I noticed how bad the spikes were on the freeway between 22-8psi,
9th October 2016, 10:15 PM
#16
Thanks matty. I only have the scanguage at the moment to monitor boost levels. I thought the dawes setup wasnt needed on the CRD patrols?
9th October 2016, 10:38 PM
#17
You won't need boost control if your just doing egr.
The ecu handles that ok..
Again it's just the exhaust which brings out some issues
10th October 2016, 09:04 AM
#18
Awesome. Will post results once I get it done.
10th October 2016, 09:43 AM
#19
I'll disagree with westy there in my instance I defiantly needed some form of boost control with just blocking the EGR mine really didn't like it, the boost spikes were before I did the exhaust and the ECU did a lousy job with the boost control especially at cruising speed, i never got limp mode but I personally think the runs better with boost control.
10th October 2016, 10:51 AM
#20
ThefattymattymkII
Yea agree it's better with boost control.
I could feel it surging in the higher gears.
But I never saw above 15 psi on the scangauge.
I did disconnect the battery for the hour or so while doing it..
Wether that has affected the ecu and it's relearnt it's new perameters I'm not sure..
