Results 11 to 20 of 34
Thread: Gu sliders project
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    Centre supports all notched in.
    Just a thought do you think the 50 x 50 is big enough for an air tank,
    might hold more than you think, as I said just a thought.
    still looking good lol
  4. #13
    Sep 2014
    Port Macquarie
    Now your talking. Bloody great idea. If my calculations are correct, it should hold 3.3 litres each side.
  5. The Following User Says Thank You to mjr350 For This Useful Post:
    BigRAWesty (6th March 2016)
  6. #14
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Nice work...
  7. #15
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by mjr350 View Post
    I still don't understand why you welded the ends first before fitting those spacers in. You had to either force them in or have a sloppy fit before welding..
    John
  8. #16
    Sep 2014
    Port Macquarie
    They slipped straight into place because of the 15 deg angle. It would have been an issue it was straigh.
  9. The Following User Says Thank You to mjr350 For This Useful Post:
    jff45 (21st March 2015)
  10. #17
    Sep 2014
    Port Macquarie
    This gives you an idea of the finished product. Need to drill a few more holes for the front mount and rear u bracket, pray for a clear arvo tomorrow and hopefully at least tack it in position.
    Before anyone says anything. No the pipes are not welded in position. I just sat them there.
  11. #18
    do you think you need to 45 the front to stop it digging in .?
    Just throwing stuff out there,
  12. The Following User Says Thank You to threedogs For This Useful Post:
    mjr350 (22nd March 2015)
  13. #19
    Sep 2014
    Port Macquarie
    Oh yea thats on the cards. I'll be 45ing the bottom 2/3rds of the end, not the whole end if you know what I mean.
    I prefer that look and less sharp angles.
    I left the ends of the 50x50 a little longer so i can trim them when its in position to get the right look.
  14. #20
    Yeah anything with a leading edge to help it "slide" will work good stuff
