31st May 2016, 06:48 PM
Muskee84
Stupid question which goes to + and -
Same as if it's fitted to the vehicle.
- to the housing/body.
+ to the main positive terminal on the solenoid.
You will also need to supply a + to the smaller terminal on the solenoid.
Or you could take it to your local Auto Electrician to test.
31st May 2016 06:48 PM
2nd June 2016, 06:55 PM
Couple of hits to the starter and the missus cranking and boom she started. Changing it on the weekend. Do they have a gasket or can I use hi temp silastic
7th June 2016, 01:12 AM
Muskee84
Not a bad idea to apply a thin layer of sealant around the seat, but mine(GQ RB30) fitted as it is. But, I reckon if you go mud off roading, then a tiny bit of sealant seal probably not a bad idea.
