Results 1 to 4 of 4
Thread: Front air dam
    central qld
    Front air dam
    hi there just wondering if anyone has a diagram of a front air dam gu 2003 td4.2 stl https://unsealed4x4.com.au/wp-conten...-Airdam-2.jpgs , as the 2003 model is bigger looking to make one
    I made one years ago for my GQ, i actually made it to help with Bow wave for River crossings and Mud bog holes. It was an easy thing to bend up. I screwed it to he chassis crossover and the base of the radiator support. worked a treat. I think @AB might now have it on his car. It was mega easy to work out. 3 section, 2 fold piece. each fold is 45degrees.
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    braz-3.0l (21st July 2023), rusty_nail (28th June 2023)
    581 Post(s)
    I never fitted it and @Rossco stole it off me years ago lol
  6. The Following 3 Users Say Thank You to AB For This Useful Post:
    braz-3.0l (21st July 2023), MudRunnerTD (30th June 2023), PeeBee (29th June 2023)
  7. #4
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Had one of those front bash plates that bolt to chassis rails but totally be a bad outcome if jammed up into the steering linkages, so took to it with an angle grinder, cut 70mm off lip and bought some 20mm conveyor belt scrap that will be attached (maybe metal strip w/nuts, bolts) _ cardboard is the concept (fill in gap between rails). Finish it some day.
  8. The Following User Says Thank You to Bidja For This Useful Post:
