25th June 2016, 05:00 PM
Gq transmission rebuild
Hi all my teansmission is fine but as I am restoring thr car. I would like yo open the manual transmission
What should I look for
Will replace all gaskets and seals
25th June 2016 05:00 PM
25th June 2016, 05:47 PM
if it aint broke - dont touch it
thats the best
The Following 3 Users Say Thank You to Bigcol For This Useful Post:
dom14 (25th July 2016), NissanGQ4.2 (25th June 2016), Wine_maker (27th June 2016)
11th July 2016, 02:08 PM
Mrme4u
If you know what you're doing, and the box has done over 300,000km it doesn't hurt to throw in a new set of bearings as preventative maintenance.
Based on a box not showing any signs of problem or wear -
Look for wear in the 4th to 3rd and 3rd to 2nd syncro rings, collapsed springs/wear in the selector detent mechanism, and wear on the teeth of the small gear in 5th gear set.
Bearings and seals will take care of the rest.
The Following 2 Users Say Thank You to Arfa Brayne For This Useful Post:
Col.T (2nd August 2016), dom14 (25th July 2016)
24th July 2016, 07:19 PM
If you decide to open it, go for full overhaul.
25th July 2016, 09:56 PM
kroggy
Overhaul kit is over $500. I reckon it's worth getting it done by a professional by adding another $500, unless we
are happy to spend time on doing and learning.
29th July 2016, 05:38 PM
Arfa Brayne
Do you know a place gearbox parts like synchro rings, bearings, gears, etc can be bought individually, rather than buying a kit with many parts that don't need replacing?!
