Results 11 to 20 of 26
Thread: What are good brand air intakes ?
    Expert First Pooy's Avatar
    Mar 2018
    The brand is K&N,and yes it comes with the pod filter but before I could ask why he was selling it he got pissed of and basically said take it or leave it
    330 Post(s)
    Interesting that that pod is mounted towards the air so it filters from the inside out instead of outside in. Not sure whether that will effect its performance? Id have thought it will block sooner as any rubbish will sit inside the filter rather than the box. Leaf litter etc will ball up in the centre of that filter.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Hodge (26th November 2018)
  5. #13
    193 Post(s)
    You are spot on, its incorrectly mounted from a coarse filtration perspective.
  6. #14
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Yeah, it is hard to see from the pic but the pod I bought for mine today has the flange to mount to outlet spigot pipe (being larger filter dia at this point) and at the inlet end being smaller dia which is capped off so that the inlet air is circulated around o/s of pod and thru to inside core for filtration.
  7. The Following User Says Thank You to Bidja For This Useful Post:
    PeeBee (26th November 2018)
  8. #15
    Jul 2017
    37 Post(s)
  9. #16
    Jul 2017
    37 Post(s)
    PeeBee and MudRunnerTD, pick up on a point that prompted me to have another look at your pic. If you cannot fit a 9" pod filter with the smaller dia (blanked off) facing toward the inlet side (snorkel end), as show in my pic, I would not buy it.
    I received mine as illustrated in the mail today, new (with out filter) $340. Filter cost is $85=total $425. This guy is self employed boiler maker and does a good job (I am pleased). Yet to install as waiting for 4" snorkel. You can buy similar thru Fatz Fabrication $680.00 complete. Mine is not powder coated (not an issue for me, as it depends on how it works that matters).
    Makes them for TDs and ZD
  10. #17
    Mar 2018
    Interesting stuff thanks for your comments guys
  11. #18
    Mar 2018
    I am about to drop 5300 hundred on a new pump and turbo and that is more then pushing the limits of my budget so can I temporarily just put a pod filter just off the turbo until I work out my air box I really need to get my intercooler pipes in and the standed bix is in the way
  12. #19
    460 Post(s)
    With Detergent and water.
    It's good to have 2 So you can swap them out without the need to give up the car for a few hours
    Yeah thats what I do. Same with the catch can filter.
  13. #20
    330 Post(s)
    Quote Originally Posted by First Pooy View Post
    It will work but not ideal as you will not be able to tune it like that or it'd be pointless tuning it like that i should say.
