Page 111 of 116 FirstFirst ... 1161101109110111112113 ... LastLast
Results 1,101 to 1,110 of 1157
Thread: Winnies 747 TD42 GQ
  1. #1101
    201 Post(s)
    Thanks guys. Got a message from Nissan newby and he reckons it's M12x1.5mm
    I will grab one on Wednesday now and hope it is right but it does sound good.
    Had issues at Enzed this morning, the reckon M10x1.5mm is very unusual and they have had to order stuff in so I am hoping it is all here before the weekend.
    190 Post(s)
    Winnie, maybe a typo but M10 x 1.5P is a standard metric coarse thread pitch, about as rare as politicians lies! M12 x 1.5 is equally as common as a metric fine pitch, so no idea why they told you that. It might be a rare liquid fitting though, however they have every adapter under the sun avail t them, again should not be an issue.
  4. #1103
    201 Post(s)
    Yep, could not buy an m10x1.5 to -4an adaptor from Enzed. He did help me with where to find one (the internet) but I bloody hope it arrives before the weekend.
  5. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    PeeBee (6th November 2018), threedogs (7th November 2018)
  6. #1104
    190 Post(s)
    Do you have the room to do it it in a couple of steps, instead of a straight M10 to AN4 config?
    Did ou try autobarn or super cheap by any chance?
  7. #1105
    190 Post(s)
    I have dealt with these guys a bit and they will slam one in an express bag for you, no problems, just takes a call if you are in doubt with the other one.
    https://www.ebay.com.au/itm/Metric-A...8Bs:rk:21:pf:0
  9. #1106
    201 Post(s)
    No I haven't tried them. I ordered from a company in Sydney called Earl's speed parts. He express posted it yesterday, and other than that the bloke at Enzed reckons he will have the parts to make my hoses tomorrow which I will take home and get lined up, then take back to him so he can crimp them
  10. The Following User Says Thank You to Winnie For This Useful Post:
  11. #1107
    190 Post(s)
    Hey as an option, maybe too late, Enzed do sell a light blue hose with barb fittings that dont need any crimping or clamps. You cut the hose and push then fitting into the hose. They have to be cut off with a stanley knife to get them apart. They are widely used in the mobile construction/mining game. I used this system on my hydraulic winch and it is so simple, no leaks at 3000psi and 90 degC, think they are rated at 300degC from memory.
  12. #1108
    Only the kool kids run double vac haha.
    I got the vac pump and flywheel today. Need to get the flywheel machined up and a hose made for the vac pump.
    Hi Winne are you getting the fly wheel lightened ,,or not worth itt??
  13. #1109
    22 Post(s)
    Lightened and a balance..... it should be
    96 GQ coil/Cab
    08 G6eT
  14. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    threedogs (10th November 2018)
  15. #1110
    201 Post(s)
    The only local place that could do it wanted $1200 to get it balanced and lightened.
    I ended up getting it machined at another place.
